Thanks a lot
AW: UPDATE - Minix Neo X7 - wasser firmware 1.0.4 - KitKat Android 4.4.2
Originally posted by KingNothing View PostSome months ago, I installed previous versions and I had problems with screen flickering (probably depending even on my sony tv).
This problem is solved in the new version ?
Originally posted by julioforo View PostHi all..
I'm trying to watch a video recorded with my slr... it's recorded in 1080 and 60 frames.
I can't find any player that reproduces the video without jumps...
Mx, bs player, xbmc...
Any advice please?
Same problem with 1.04 and my LG LCD in 50/50hz... so i use 1080/24Hz and no problem so far.
What Kernel im using and no DTS
First of all, hello. I just bought my first android media device and im brand new to this.I flashed my Minix X7 with the wasser version 1.04 and i now have two questions:
Is the 1080p kernell embedded in this one? How can i know if im running the 1080p kernel or the 720p (probably a stupid question hehe but im a total noob). This because i am seeing a slight lagg when playing 1080p files.
I would like to have DTS. I am using an optical cable directly from the box to the AMP. I have set the XBMC settings on passthrough and 2.0. In the rom ive set it to Rockchip-SPDIF passthrough but i dont have DTS in any way.
Please can someone help me out?
Thanks!
Thanks!
For DTS you can use either SPMC (you can find it on Google Play) or Kodi with passthrough from here:
http://www.freaktab.com/showthread.p...d-libmedia-so) Wasser's 1.0.4 has modified libmedia-so. You can also use Wasser XBMC. It has passthrough, but you have to enable it in XBMC-- system--settings--system--audio output.Last edited by Kiralina; 26 October 2014, 12:19.
Originally posted by Kiralina View PostWasser 1.0.4 comes by default with 1080 kernel, but you can also check it in XBMC system--system info.
got DTS working now.
Does anyone else has the problem that XBMC is not very stable when dark images are processed.? Its in the menu's but also during playback. Like its not "leveling"on the right brightness or something.
Re: UPDATE - Minix Neo X7 - wasser firmware 1.0.4 - KitKat Android 4.4.2
Any advice please?
Scribed henceforth from thy G pad.
Can anyone help me out?
thx
There are currently 2821 users online. 1 members and 2820 guests.
