Inviato dal mio A0001 utilizzando Tapatalk
Originally posted by galock View PostHello, may I use this rom on ugoos ut2 8gb version? I've read in the op that there are 16gb in one partition and since Ihave a 8gb unit I'm afraid it could brick
Inviato dal mio A0001 utilizzando TapatalkFLHT = Harley
HEMI = 2010 Dodge Challenger SRT
Cause I've been asked.
UPDATE - Minix Neo X7 - wasser firmware 1.0.4 - KitKat Android 4.4.2
Originally posted by flhthemi View PostOK, thanks for the help!
EDIT: Got Wasser installed!
The only ~problem I'm having is that now the T428 isn't seeing my Tronsmart USB Ethernet dongle. So, no wired connection but the wifi is working. Anyone know if there is something I can change to get it to find the USB Ethernet dongle? Maybe a different one with a different chipset or an edit to some system file??
why you're not using the on-board ethernet conector and you're using the tronsmart usb ethernet dongle on your minix ... the on-board one is broken ?
Originally posted by windhelper View PostI have a question ... i'm new with this and i'm tring to understand how the minix x7 is working
why you're not using the on-board ethernet conector and you're using the tronsmart usb ethernet dongle on your minix ... the on-board one is broken ?FLHT = Harley
Originally posted by flhthemi View PostNo, I wasn't using the ROM on a Minix. ROMs for some devices will work on other devices because they happen to be similar in design. I use this ROM on a Ugoos UT2 and I like it so much I decided to try it on my Tronsmart T428. It worked well execpt for this issue. I just couldn't stand not being able to get a wired connection so I reverted to using the Finless ROM on the T428.
- do I need to install a new rom and if so, do you know a version that remove this bug, and don't have others (bugs)?
by the way the build number is kot49h .... i've search on minix.com.hk and have no idea if I can use a rom from there
@windhelper
I see no problems like this with wasser 1.04 (this ROM) on my Ugoos UT2. So I can't comment about this ROM and X7 as I don't own one. I also don't recall reading of anyone having this issue on the X7...but I don't read everything everywhere
What you are saying is that the brightness changes on it's own? Sounds like it might be "flickering" which I have seen some posts about.
Sometimes if you flash the same ROM again it fixes problems like this. I've read several posts about a problem that arises from a new ROM being flashed and re-flashing the very same ROM fixes the issue.FLHT = Harley
Sometimes if you flash the same ROM again it fixes problems like this. I've read several posts about a problem that arises from a new ROM being flashed and re-flashing the very same ROM fixes the issue..... i'll keep diging
Updated to Wasser 1.04 kk from finless 1.9 jb
I flashed 1.04 yesterday and I am glad to say that this is a great rom. I have tried several other kk roms, this is by far the best. As far as set up goes and features for the end user jb has nothing on this. The display looks identical. The passthrough is great too. No troubles whatsoever. I have a question, I want to upgrade wasser xbmc 1.2 to 1.3. When I do, will I lose my xbmc configuration? I did back it up allready but it has been my experience in the past that xbmc restore does not restore all of it the entire way it was before. I allready installed 1.3 after my install last night, but after I set it up today I realized I was still running 1.2. I'm not sure how that happened, but it did. Thanks for all of the hard that went into producing such a great rom. Thanks, Kevin
Originally posted by smokie171 View PostI flashed 1.04 yesterday and I am glad to say that this is a great rom. I have tried several other kk roms, this is by far the best. As far as set up goes and features for the end user jb has nothing on this. The display looks identical. The passthrough is great too. No troubles whatsoever. I have a question, I want to upgrade wasser xbmc 1.2 to 1.3. When I do, will I lose my xbmc configuration? I did back it up allready but it has been my experience in the past that xbmc restore does not restore all of it the entire way it was before. I allready installed 1.3 after my install last night, but after I set it up today I realized I was still running 1.2. I'm not sure how that happened, but it did. Thanks for all of the hard that went into producing such a great rom. Thanks, Kevin
I backed up the wasser FILES folder that is on the SDCARD from inside wassers xbmc folder. The entire Files folder. Backed up to a hard drive on my PC.
Then I uninstalled Wasser V1.2 of xbmc
Then I installed Wasser V1.3 of XBMC
Then I ran it for the first time
Then I went in to SDCARD wasser xbmc again and deleted the new Files folder that got created on first run
Then I copied my backed up files folder to the wasser xbmc folder
Then started xbmc and all is well!
Now, I'm not sure this method is "proper" or not, but it worked for me. I think if you just backup your addons folder, userdata folder and copy them back after installing V1.3 and running it for the first time you'll see that it works too.
Anyway, someone's going to post about the "proper" way to do this. I do not like the xbmc backup addon either. It seems like it leaves things incomplete.....to me.
But then I'm a jackleg N00B that knows nothing anywayFLHT = Harley
Originally posted by windhelper View Postthx for the answer ... I'll see what can I do .... the real problem of the rom on my x7 is that it hasn't any settings for the brightness or the button for the auto brightness.... i'll keep diging
FLHT = Harley
a little help anyone .... i've tried to flash my x7 with the rkbatchtool and failed to upload the image and now the device won't start and when I plug the cable in the device to try an other flush ... the icon in the app goes blue and then disappears from the app (and the usb port is showing something conected and then the icon of the usb device also disappears ) ..... the freaking thing seams to be dead ... any ideeas guys ???
Try pressing and holding the on-button on the device but release only the reset pinhole.
Keep holding the button while it's flashing. Worked for me to reflash to 4.2.
I have another issue. I'm trying to connect to Android Studio on OSX but the Minix is not detected on the OTG USB port. Is this normal (with Wasser v1.0.4)?
I tried to connect with my TabS and it does work but not with the Minix7+Wasser 1.0.4.
There are currently 2614 users online. 1 members and 2613 guests.
