Originally posted by BTR11 View PostThanks wasser for your great & hard work; I will give a try, coming from 2.0.2 which it´s working fine for me.
Can you consider, please to add to the firmware, if It is feasible, that the "Screen Scale" options to adjust/fit the screen can handle the four sides independently from each other, I mean, up & down separately (not as it is now combined vertical screen adjustement), same for horizontal screen adjustment, left and right separately?; exactly that it´s been done currently for the rk3288 (R-89 with your firmwares). In some TV´s models this way to fit to the 100% of the screen make the difference.
The Neo X7 with your rom had been reach a very mature point, exceeding in many situations the day to day performance of newer and poweful systems like A80 & rk3288; Minix owe a lot to you; you had shown to them the way to implement properly android 4.4.2 with all of the goodies and the single 16Gb partition on RK3188; if still they are selling Neo X7 it´s because of your good work had help them a lot. Thanks again for your wonderful work.
Wasser
Hello
Thanks for the rom.
I flashed latest today, I had nitroteam 1st rom ever since I purchased neo x7.
There is a definite improvement, only one thing!
My screen goes blank every so often, not flickering! what is this & how can I fix it please.
I tried to read most post but couldn't find related topic.
Cheers, I look forward to getting on top of this.
Originally posted by chrisofnaki View PostHello
Thanks for the rom.
Originally posted by kokoui View PostHello wasser, thanks for your great work. you have given life to our device. Will the oc kernels work with 2.0.3 ? or are you going to release new ones for that version
Originally posted by wasser View Post
the download url is fixed. Please download it and test if it works. Please post the result!
Originally posted by brezix View PostHi, flickering is gone (panasonic tx-50vt20e), but there is some issue with ethernet. KODI buffering over ethernet is every 10sec. Can you make this kernel with OC cpu ddr ...?
I uploaded new OC kernel with hdmi_flicker fix. Thanks for your feedbacks!
Enjoy
Wasser
Originally posted by chrisofnaki View PostIf I use the flash img kernel command, will it flash even though it is zip.
My wife is hogging tv and I got to get to sleep for work.
Would much rather do this though.
Thanks heaps
No problems so far with 2.03. My logitech c525 can take pictures and video. Kodi works great. Not checked skype with 2.03 yet. Will update you.
I flashed the 2.02 OC kernel yesterday onto the 2.03 firmwire and I have had no problems. I will update to the new one today.
Truly grateful. I have a new baby and on paternity leave, being able to have a smooth running android box allows me to get a bit of work done and then skype the family intermittently while baby in one arm.
Nice one.
Update:
New kernel is great. No bugs found yet. Skype works.
Very happy with this ROM.Last edited by andyffoo; 21 May 2015, 00:36.
There are currently 2205 users online. 0 members and 2205 guests.
