Originally posted by Pluto View Postwhat goes first? i know the kernel is on the boot.img, hence why i ask?
The commands you list are fine.
Originally posted by robertlemke4 View PostAnd a another question: is there a way to hide the plugged sdcard, usb-stick and external hdd-drives from the notificationbar (upper left)?
- Expand the notification bar and long press one of the storage notifications
- Select the "App info" option when it appears
- Tap "Force stop" to shutdown the 'System UI' app
A permanent option would be to uninstall the 'System UI' app but that might have a negative impact on system stability.
Originally posted by Molle View Post
I'm currently running 2.0.3 with the oc'd kernel, patched boot and TWRP-2.8.5.0. Each of the three can be installed with 'flash_image' in the terminal emulator.
Edit: Never mind, I had found it. (Abdul thread).Last edited by BTR11; 27 May 2015, 03:12.
Originally posted by BTR11 View PostMolle, pls can you share the recovery image TWRP-2.8.5.0 that you are using with wasser v2.0.3 for Minix NeoX7?. Sorry if you postede before, I can not find it. Thanks.
Originally posted by chrisofnaki View Post
Lol, can you please post a link for twrp.
It´s working good, giving proper functionality for the Minix A2 air mouse that It was not working with the stock system recovery image v. 4.4.0.Last edited by BTR11; 27 May 2015, 19:52.
Originally posted by Pluto View PostSeems like Popcorn Time doesnt acknowledge the Ethernet as a proper connection, it wont load anything without WiFi.
Also, anyone having any issues with Xposed, i did get a few reboots after loading GravityBox and GEL Settings.
Solid performance so far...
Originally posted by Mario023 View Post
Sorry.
Can someone explain step by step?
I like Wasser rom but I have screen flicker.
su
flash_image kernel sdcard/download/neo.img
reboot
There are currently 2178 users online. 1 members and 2177 guests.
