Robert Lemke | Cologne (Ger)
Originally posted by robertlemke4 View PostWhy would like you to use, actually, absolutely of this ROM for T428?
Robert Lemke | Cologne (Ger)FLHT = Harley
HEMI = 2010 Dodge Challenger SRT
Cause I've been asked.
Can some point me in the right direction?
Not sure if this is the right place but this is one of the few roms that have all the memory in one location. I think this is called a "16 gb partition". I would like to do this on another android box that I have. When I use zero cacheing in xbmc I have no issues everything works great. This box has 16 gb in one location. On my other box it is split it two. I want to make one "partition" or all the memory in on lump sum like on my neo x7 Wasser rom. I tired searching Google on how I could learn to do this. But everything that came up had something to do with SD cards. My neo x7 has 16gb with Wasser and a 64gb sdcard. If someone can help me I would be great full.
Originally posted by flhthemi View PostWell I'm done. Flashed it again and still no ethernet, only wifi. So I just went back to Finless 2.0 and it's fine. I'll just stay here, it works on the T428.No sence in wasting more space on here about it.
After trying to connect I confirm ethernet on wasser 1.04 on T428 is not working. I think it is a driver issue since X7 have a different ehernet card.T428 ,Radxa Rock (RR), cs918s v1.0, waiting for my X7...
Originally posted by Sarco View PostI am a little bit confused, you do not have ethernet on x7 or T428. On my T428 I have ethernet with wasser 1.04, in my setting.
After trying to connect I confirm ethernet on wasser 1.04 on T428 is not working. I think it is a driver issue since X7 have a different ehernet card.FLHT = Harley
wifi connection problem
Hi guys,
I have neo x7 on wassers 1.0.4., and my wifi connection speed currently is something about 1-2 mbps according to speedtest. Previously I think I had about 10-12 mbps, and while this was not perfect but still it was OK.
Xperia z2 tablet and note 3 smartphone on the same network are showing 40 mbps at the same time.
Is there anything I can do to fix this? Had no luck with factory reset.
Has anything new been added to your network, wifi or wired recently? There could be a conflict of addresses between two devices. I just experienced this on my network. A T428 was battling with my wife's tablet for 192.168.1.97. Once I resolved this situation the T428 was back to being solid at 44 mbps.FLHT = Harley
Is there anything I can do to fix this? Had no luck with factory reset.T428 ,Radxa Rock (RR), cs918s v1.0, waiting for my X7...
Google Play Music on Wasser 1.04
Hi Guys,
I'm currently using Quickshot v3.1. It's OK, but unfortunately Google Play Music doesn't work as it stops after playing the first song in the playlist.
I've found some posts about the same behavior in Wasser 1.03 and a post from Wasser himself telling us that fixing this is on his ToDo list.
My question is that is it working properly in Wasser 1.04?
Thanks,
p
I've succesfully flashed Wasser 1.04 but Google Play Music doesn't work as expected... It stops after playing the first song in a playlist exactly like in QS v3.1. I have tried all the combinations in Settings/Sound/Sound Devices Manager without any luck.
Is there any solution for this? It's really annoying that I can't use my media player to play songs from Goole Play Music...
Thanks,
p
There are currently 1777 users online. 1 members and 1776 guests.
