Pls look @ post #1953
Logitech Harmony Remote Mapping
I just installed Wasser ROM and the XMBC 1.3 that goes with it. I used to use Finless 1.8 and I had the remote keymap modified to work with my Logitech Harmony Remote so I could use the stop/play/pause etc buttons within XMBC and it worked awesome.
Anyways I copied the .kl and the keymap files over into the correct locations and it still does not work.. Is there something different I must do in Wasser to make this work than I did in Finless?
Originally posted by Rokgaw View PostI just installed Wasser ROM and the XMBC 1.3 that goes with it. I used to use Finless 1.8 and I had the remote keymap modified to work with my Logitech Harmony Remote so I could use the stop/play/pause etc buttons within XMBC and it worked awesome.
It could be nice to get it to work in Wasser firmware...
It works here on Minix neo X8
We need to integrate X5 remote settings into Wasser firmware
Pleass is there someone that can help with this???
T-J@Y
@wasser: How did you make your ROM use a single partition? I want to do this on my rk3188 device. I tried using your partition layout, but it's asking me for a password to decrypt storage.
Edit: Nevermind. I called the last partition user instead of userdata. Everything is working now.Last edited by FreeBullets; 03 November 2014, 06:43.
Problem 3d movie player
Hello everyone,
I have a problem with the neo minix x7 firm v8 and playback 3D movies from xbmc.
I tested with versions beyond, xbmc minix, SPMC and wasser and all tests with different movies. The problem I have is that I can not play well, the movie is not well displayed and a little out of focus.
I wanted preguntarios if when playing a movie with minix x7 is a submenu for configuring parameters for 3d if you know what works and what I can change to solve my problem?
I've also tried with dvd player and arcks reporductor and mx player.
is RK flash tool the only recommended way to flash this rom? I'm unable to get into flash mode and have my pc recognize my Minix is there. i know it used to work. it's how i flashed 1.7 and 1.8 finless. I can however easily reach RK recovery... can this rom be flash via recovery? tia
Sent from MINIX X7
key 116 POWER WAKE
key 143 NOTIFICATION WAKE
key 28 ENTER
key 102 HOME
key 139 MENU
key 158 BACK
key 217 SEARCH
key 103 DPAD_UP
key 105 DPAD_LEFT
key 106 DPAD_RIGHT
key 108 DPAD_DOWN
key 232 DPAD_CENTER
key 113 VOLUME_MUTE
key 114 VOLUME_DOWN
key 115 VOLUME_UP
key 402 MEDIA_PLAY_PAUSE
key 66 MEDIA_STOP
key 67 MEDIA_REWIND
key 68 MEDIA_FAST_FORWARD
key 87 MEDIA_PREVIOUS
key 88 MEDIA_NEXT
graphic bug with order and chaos online
I always use the roms for the mynix x7 on my t428 because they are perfectly compatible and stable with my device.
Latest wasser rom is working perfectly but i have a problem with the game order and chaos online my graphics are messed up with my avatar. Is there someone who tried that game with wasser rom? I would like to know if it is a compatibility issue with my t428 or the rom itself with the game
Thank you!
Wasser Wasser Oh Wasser
Proficiat Wasser
After manny manny roms and done installing them
I thougt today lets take a look at freaktab again and saw your new rom
Installed it and gues what first thing i installed netflix and in a few minutes time i was amazed
So i have a good feeling with this rom
Thanx Man i wil try more this weekend tumbs up
Sd card
Originally posted by cyrusalmighty View PostIs the "Move to SD card" option still in Settings> Application Manager? I cant move any User apps. I dont see it so Im wondering if its because I formatted my 64 micro SD card to Ntsf. I know this option is on my ATT Galaxy S4 4.4 Rom.
Flickering . . .
Forgive me if the topic has already been treated. I have difficulty reading English, and a search result is very complicated. Particularly in 100 pages and more ...
Today they are migrated from Quickshot v.3 to Wasser 1.0.4 with default settings
I realized during views with the dark background of a highly visible and annoying flickering.
No way to eliminate or at least reduce it?
Apart this problem seems to me that the firmware functions well ...
There are currently 2410 users online. 1 members and 2409 guests.
