Other than what is listed in Changelog, is there any great differences in version 2.03 from 1.04? I found 1.04 very stable and it played many videos great but I have bad wifi droput and at times no connection. This may be hardware on X7 and not Rom fault at all of course. Now I mainly use box for streaming Video on KODI now so Wifi is needed. Can anyone please share some screenshots?
Originally posted by midelpo View PostDolby and DTS passthrough no longer work with MX Player or other player in 2.0.3. Works only in kodi.
Both see the digital stream and pass it thru but my amp, Yamaha A1010,
does not detect a steady digital stream, and drops out of digital mode every few seconds
I have tried Default and HDMI bitstream in the sound settings
but both behave the same
Also the spidf setting
Any ideas?
Originally posted by astral69 View Post
Passthru is not working reliably for me on MX Pro or Kodi 15
Any ideas?
ThanksLast edited by Molle; 21 July 2015, 07:42.
Originally posted by astral69 View PostSo I guess I have to manage without Passthru for the time being.
Thanks for all the advice on Passthru
I just tried all the players in turn via ES file manager
The two standard players worked
MX Player PRO failed completely saying the codec is not supported
and KODI gives the broken stream
My problem with direct access via the standard players, is the way they view the files,
just presenting all the files on the disk in a long list, ignoring the folder structures.
All my files are on a 2Tb disk and there are lots of them, so an organised view is essential
At least I can get the passthru now
Originally posted by vovkoon View PostSorry, but I do not have time to read the whole forum, tell me how to install kernel.img?
Hi Guys,
I'm using Wasser 1.04, the newer versions are unstable on my X7. I'm happy with 1.04 with one exception: Google Play Music sometimes doesn't work as expected.
I've noticed that there's a patch for Wasser 2.02 (actually it replaces system/lib/libmediaplayerservice.so).
Can I use it on Wasser 1.04? Is it safe to install it (by hand)?
Thanks,
palLast edited by pal444; 02 August 2015, 19:39.
Originally posted by pal444 View PostMr. Wasser, Mr. Molle?
Could you help me?
Originally posted by Molle View Post
Versions 2.0.2 and later are based on a newer SDK than the earlier releases. Mixing libraries between them might not be a good idea. Maybe Wasser or another developer could verify this.
Thanks for the reply.
That was my assumption, based on the available info - that's why I haven't istalled the patch. Can I reach Mr. Wasser somehow?
There are currently 2651 users online. 1 members and 2650 guests.
