Originally posted by milouk View Post
Originally posted by EagleEyeXZ View PostI also tested wasser kodi 15.2 i do have dropouts when i turn off rockchipcodec but diffrent then original kodi
Originally posted by Molle View Post
Interesting. I was actually concentrating more on the signal light of my receiver than the actual sound. Besides being audible, the drop-outs in DD/DTS signal also turn the decoder indicator on/off on my receiver's front panel. With Wasser's Kodi version there were none for the duration of the few test clips I played. With Kodi-16.1 they are painfully obvious.
Please give me the feedback and the adb log file!
ThanksLast edited by wasser; 01 February 2017, 00:45.
Originally posted by Molle View PostWell, I installed 3.0.5 Yesterday for a test spin. Everything else seems to be working except, yes, multichannel audio passthrough. The installation procedure I used was:
* Used RKDevelopTool to wipe IDB twice
* Flashed the ROM using the batch tool
* Booted to ROM and allowed it to settle
* Updated the audio.primary library
* Powered off and used RKDevelopTool to flash TWRP, the oc'd kernel and my Mali-patched boot image
I initially tried to flash recovery, kernel and boot from within the ROM using flash_image and QuickFlasher but both failed to write to the respective partitions.
External HDD is working fine but it seems that it's not possible to mount more than one USB device at a time. When I attached a USB memory key in addition to the HDD, the stick was not recognised.
About passthrough and various players:
* Internal video player: stereo
* MXPlayer: stereo
* Kodi 16.1: Multichannel, but drop-outs every 2-3 seconds
* SPMC-14.2: static
* SPMC-16.5.5: static
* SPMC-16.2RK: static
Originally posted by Molle View PostExternal HDD is working fine but it seems that it's not possible to mount more than one USB device at a time. When I attached a USB memory key in addition to the HDD, the stick was not recognised.
Originally posted by EagleEyeXZ View Posthe wasser i cant replace the last file. i tried 2 times but Android crash and doesn't start again. i think you have to recompile to make it work.
There are currently 1918 users online. 0 members and 1918 guests.
