Originally posted by EagleEyeXZ View PostHe wasser tested rkmc build from jan 6 2017.. no audio passtrough just loud noise... the .cpp files on official kodi 16 build detect ac3 or dts you only get hickups maybe a special kodi build is needed with a little patch.. if there is something to test let me know. On the weekend i will search spdif cable so i can test for you
and push it to /system/lib/hw/ . After that reboot the device and test again. Please give me the feedbacks, thanks!
Wasser
Wasser, thanks for the new 3.05 firmware, but I have a problem with my Airmouse A2, if the transmitter is plugged into the USB port, the sound, no matter what goes on in the sound settings, goes through the Airmouse. If the transmitter is disconnected, then the sound works fine through HDMI. Is it possible to make a setup sound the same as in the 1.04 Firmware, everything was perfect.
link to the flasher: this - https://cloud.mail.ru/public/5gMQ/X8xNGuw61 or this, if first dont work - https://cloud.mail.ru/public/FUr2/KHqNHS7d2 + mini-instruction on photo + link to file "parameter" (https://cloud.mail.ru/public/HXSj/UsJU84Q6G). parameter load to 2 line, kernel - to 7 line. remove all check marks except the kernel, connect device and flashYou may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
Originally posted by wasser View Post
EagleEyeXZ, jmcm i uploaded the new audio.primary.rk30board.so which maybe fix the hdmi passthrough issue. Please download it from http://www.freak-tab.de/wasser/audio...y.rk30board.so
Wasser
Thanks.
Well, I installed 3.0.5 Yesterday for a test spin. Everything else seems to be working except, yes, multichannel audio passthrough. The installation procedure I used was:
* Used RKDevelopTool to wipe IDB twice
* Flashed the ROM using the batch tool
* Booted to ROM and allowed it to settle
* Updated the audio.primary library
* Powered off and used RKDevelopTool to flash TWRP, the oc'd kernel and my Mali-patched boot image
I initially tried to flash recovery, kernel and boot from within the ROM using flash_image and QuickFlasher but both failed to write to the respective partitions.
External HDD is working fine but it seems that it's not possible to mount more than one USB device at a time. When I attached a USB memory key in addition to the HDD, the stick was not recognised.
About passthrough and various players:
* Internal video player: stereo
* MXPlayer: stereo
* Kodi 16.1: Multichannel, but drop-outs every 2-3 seconds
* SPMC-14.2: static
* SPMC-16.5.5: static
* SPMC-16.2RK: static
Originally posted by Molle View PostWell, I installed 3.0.5 Yesterday for a test spin. Everything else seems to be working except, yes, multichannel audio passthrough. The installation procedure I used was:
* MXPlayer: stereo
* SPMC-14.2: static
Originally posted by milouk View Post
can you provide please the link for twrp recovery for 5.1.1 Lollipop?
I used the same one as with KK. Didn't test all functions yet, though. So, it's possible there will be some issues:
http://freaktab.com/forum/main-categ...048#post419048
which one did you use ? the sdcard or the datamedia? ( i suppose the landscape one)
Originally posted by Molle View PostAbout passthrough and various players:
* Kodi-17.0_RC4: static
Edit:
* Wasser-Kodi-15.2rc2: Perfect passthrough but no video (just shows the file list while the sound is playing). (http://www.freak-tab.de/wasser/wasser-kodi-15.2rc2.apk)Last edited by Molle; 31 January 2017, 20:05.
There are currently 2042 users online. 0 members and 2042 guests.
