Originally posted by zapto View PostGotham for Android appears to provide support for DTS/AC3 passthrough. Thus the correct step may be implementing the audio passthrough device on wasser's kitkat rom!?
anhil
Originally posted by anhil View PostPassthrough is already implemented in wasser's ROM - in order to make it work in XBMC you need to have properly modified version of XBMC (like Beyond) and a matching libmedia.so in ROM. The later is still missing from wasser's ROM.
anhil
It requires a patched version of libmedia.so ... and a modified version of xbmc."
(http://minixforums.com/threads/how-t...nd-spdif.2041/)
"The problem is the android java framework which don't allow us to pass the DIRECT_OUTPUT flag via AudioTrack to libmedia.so to activate passthrough. To get around this I have patched libmedia.so to activate passthrough when the streamType argument passed to audiotrack is set to STREAM_VOICE_CALL (audio stream for phone calls) and since most people don't use their neo x5 to make phone calls with I don't think this will cause any problem."
This implementation had some issues with communications apps (e.g. Skype, Hangouts) so stafstrom made a 2nd libmedia version which corrected the issue (for mono audio).
Unfortunately this patch approach requires patching XBMC and as new versions keep appearing it becomes too demanding to patch all of them!
So, from my (candid?) point of view, developing a "proper" passthrough device for Android should be a better solution. Can anyone give some insight on this? is this approach unreasonable (e.g. because it may require modifying the android java framework and recompile XBMC against it) and/or too difficult?
Originally posted by zapto View PostI believe that the current passthrough implementation in some Android roms was designed by Staftrom:"I have created a hack to get pass through in xbmc, both ac3 and dts with hdmi and optical output.
Tnx!
Originally posted by karel View PostGreat idea, but for the time being I compiled XBMC Gotham RC1 with the libmedia passthrough patch.
anhil
SPDIF
After trying all custom roms I ended up with Finless 1.8.
Very stable,very fast and last but not least,no audio issue's anymore.
Works great with Beyond XBMC "digital audio enabled"
And in settings" rockchip/spdif" enabled.
Although all roms are nice and better than stock, I stay with Finless 1.8
If it works i will add it in 0.96 release which i plan to release at this weekend.
Some highlights of next coming 0.96 release:
- perfect fullhd video streaming
- auto hide systembar
thanks,
wasser
Originally posted by karel View PostGreat idea, but for the time being I compiled XBMC Gotham RC1 with the libmedia passthrough patch.thank you!
Re: KitKat-4.4.2 for Minix X7
Originally posted by wasser View PostHi karel, thanks for the xbmc build . could you or someone please test if it works fine with patched libmedia.so.
thanks,
wasser
Sent from Galaxy Note 3 via Tapatalk.
thanks,
wasser
Using UT2 ugoos
thanks,
wasser
I would like to try, but I have a Minix X5 and not a Minix X7. Could you make a KitKat-4.4.2 for Minix X5?
As I understand KitKat uses a 3.0.36+ kernel (the same kernel version is used in 4.2.2 roms). Does that mean that I can run your KitKat rom (system.img) with a rk3066 android 4.2.2 3.0.36+ kernel?
There are currently 3068 users online. 0 members and 3068 guests.
