Originally posted by wasser View Postdoes this dark color issue only appear by c920HD? Could you please attach the dmesg log (usb webcam connected) ?
wasser
i try c170 and it is normal picture (this is one by c170 not fullhd)
! but using https://play.google.com/store/apps/d...eption.dashcam
both cams make normal picture, but it is only one app and it can not change videopicture for Skype or other apps.
Code:<6>[76979.492101] uvcvideo: Unknown video format 34363248-0000-0010-8000-00aa00389b71
P.s. at the last stable original ROM 009 or 008 c920hd make normal picture but in 640*480 size - that is not good.Attached FilesLast edited by arhim; 17 April 2014, 14:20.
wasser
1. Settings crashes when I'm trying to open Mobile Networks
2. Google voice search crashes, google search widget doesn't work.
3. Sometimes red frame appears in google chrome.
Except that this is a great rom, thank you!
P.S. How can I add AirPin?
Originally posted by lewys View Post-Google voice search crashes, google search widget doesn't work.
-How can I add AirPin?
i have google search and voice search work really great with a2 mouse.
install airpin http://www.sendspace.com/file/rkotei
Originally posted by wasser View Postplease add kitkat version of flash to system
Originally posted by arhim View Postinstall fresh gapps or remove google search from /system/app and install from google play
Where I can get fresh gapps?
Originally posted by lewys View PostWhere I can get fresh gapps?
flash gapps-kk-20140105-signed.zip via recovery
Guest
Wasser,
Is there a chance you could research how Minix disabled hdmi detection in their latest 10b rom and then implement in your kit kat rom? Many app including Verizon fios, Comcast tv, showtime, etc wont play on your rom due to hdmi output detection. Minix just solved this issue on their latest rom.
I install version 0.95 today (I must change usb cabel for boot to flash mode).
Bugs:
1. Sound settings change to default after reboot.
2.Minix Air A2 mouse button home, switch window and options button I can not use with this rom.
3. Blue LED diode is still off.
How I can restore to original firmware?Last edited by Lachty; 17 April 2014, 21:02.
Just flash stock firmware dude, And you are back to stock.
Originally posted by Lachty View PostI install version 0.95 today (I must change usb cabel for boot to flash mode).
Bugs:
instructions for flashing with CWM
Originally posted by danny3838 View PostIs there a way to flash to .95 without losing all setting and apps installed?
Thanks in advance!
1) You'll need to unpack the img file. For Linux, follow this; for Windows, follow this.
2) Download the cwm-img-installer.zip from this thread
3) add the boot.img, kernel.img and system.img into cwm-img-installer.zip
4) copy this file to /sdcard/ on MINIX
5) flash using CWM and restart. you should be upgraded with your data partition and settings intact.
There are currently 2318 users online. 0 members and 2318 guests.
