Originally posted by ilovemymac View Postok that worked.
OK now how do you hide the system bar in KITkat like in the older os? i cant find an option under settingsOriginally posted by Finless View PostIt's not there yet. Use the free APP full!screen.
I used Xposed with Gravity Box, enabled Extended Desktop mode, changed NavBar to hide it, and made a shortcut on the quicksettings for the Extended Mode. bascially a click away to get rid of it and get it back.
Originally posted by Pluto View Posti use the RDP Client from Microsoft to access my windows machine, and most of the time, the resolution is strange due to the NavBar, it takes those last pixels away as a working environment screen. I've found another workaround which has by far made all the apps use the full screen.
Originally posted by Cantenna View PostTry set lock ui mode to phone speaker and make your adjustment on phone speaker menu.
anhil
Originally posted by anhil View PostCantenna (or anyone else): Can you confirm from your own experience that you can actually make passthrough work in Wasser's KitKat ROM by using Viper4Android or some other third party program? I would be most interested in hearing of the correct procedure for this since the ONLY drawback in Wasser's excellent ROM I have experienced is the lack of passthrough.
anhil
Passthru
anhil
and cannot see any option to enable passthru.
I am still getting the message from Minix that DTS is not supported
so audio being passed to MX Pro, not passthru as my amp is not seeing the digital signal.
Any hints welcomeLast edited by astral69; 21 March 2014, 13:58.
quick question..
what is the process for installing this rom? i got a header missing error when i tried to install it with the the included flasher... i assume you just link the minix to the PC with drivers installed and then wipe the minix x7 and then flash with the rom flasher... AKandroid tool.. perhaps it was just a botched download... i will give it another go..
There are currently 2590 users online. 2 members and 2588 guests.
