    Wasser,
    Thanks for your continued support of this project. Some comments:
    - Volume works now
    - HBO Go still stutters badly. Not sure why only on this rom vs. stock 10b, 006, 007, 008, 009 where it is fine. I have tried it at 1080p60and 50 and 720p60 and 50 which are the only settings my monitor has
    - Minix found a way to output over hdmi without getting stopped by apps that check and disallow hdmi output. They implemented this fix in their beta 10b. Are you able to find out how they did that and implement in your kit kat rom? Apps like showtime, fios mobile and xfinity won't output to hdmi.
    I'll let you know other findings once i test some more.
      Help
      Originally posted by wasser View Post
      version 0.94
      - kikat 4.4.2
      - usb webcam support
      - sound device manager
      - wifi support
      - ethernet support
      - bluetooth support
      - ir-remote support
      - init.d support
      - rooted
      - ntfs, nfs, iso, cifs filesystem support
      - preinstall es file manager
      - nova launcher
      - cwm recovery
      - added 1080p24hz, 1080p30hz
      Link download: wasser-firmware-kikat-minix-x7-0.94.zip
      please use RKBatchTool to flash the new firmware
      version 0.92
      - Ugoos Ut1, k-r42, t-r42 and minix x7 (please select the correct kernel)
      - kikat 4.4.2
      - wifi support
      - ethernet support
      - init.d support
      - rooted
      - preinstall es file manager, reboot
      - cwm recovery
      - added 1080p24hz, 1366x768p60hz support
      Link download: firmware-wasser-0.92-4.4.2.zip
      parameter files (thanks to 900supersport)
      new kernels fix ethernet, wifi, bluetooth, ir-remote issue:
      kernel-neox7-720p.zip
      kernel-neox7-1080p.zip
      oc kernels:
      CPU: 1008/1200/1416/1608/1800,
      DDR: 720, GPU: 400/600
      kernel-minix-x7-160114.zip
      CPU: 312/504/816/1008/1200/1416/1608, DDR:720, GPU: 133/200/266/300/400/600
      kernel-1080p-ddr720.zip
      CPU: 1008/1200/1416/1608/1704/1800, DDR:720, GPU: 133/200/266/300/400/600, 1080P
      kernel-ddr720-cpu1800h-1080p
      CPU: 1008/1200/1416/1608/1704/1800, DDR:720, GPU: 133/200/266/300/400/600, 720P
      kernel-ddr720-cpu1800h-720p
      cpu1704h/cpu1800h gpu798h ddr800 1080P, cpu1704h/cpu1800h gpu798h ddr720 1080P
      cpu1704h/cpu1800h gpu600h ddr720 1080P, cpu1704h/cpu1800h gpu600h ddr800 1080P
      oc-kernels-1.zip
      Be aware: it is your own risk!
      Congratulations for the great job you have and are doing.
      2 questions: 1 application and can implement the internal memory? 1 gig and little
      Question 2: the camera app is missing what can I put on?
      I offered you a beer
        Beginners question
        Sorry for beginner's question. In RKBatchTool--1.7 Upgade or Restore for 0.94?
          Restore Up rom
            I use upgrade
              Screen Scale setting
              Hi, wasser!
              Very good job - great firmware!!!
              But screen scale setting does not persist after reboot - Could you fix this problem, please?
                I used this camera application, it works well: https://play.google.com/store/apps/d...android.camera
                The problem I have is that the image is way dark. This is with any application that uses the camera.
                  I noticed if the system crashes and reboots wifi no longer works and to fix, a power cycle is required, sometimes two.
                  Also OpenVPN issues:
                  -I am unable to get openvpn Tun.ko to install and survive reboots, have to reinstall after each reboot
                  -if I connect via OpenVPN all is well but when I disconnect, box crashes and resets and consequently I loose wifi until a couple of power cycles later.
                  -tried updating busybox too, no dice
                  everything else looks and works great from what i can see. love the new features and am very happy to see recovery can talk to ext-sd now
                  Unfortunately, im dependent on USA Netflix and UK Netflix because Canada Netflix ain't so great, lol! i am back on 92 for the time being, but, i did flash the new recovery to 92 from 94
                  thanks again for the update. cheers!
                    Cantenna, make sure you update busybox where it is already installed. The stock VPN i use works well, behaves normally after disconnecting, could be app related.
                      Thanks for the advice. I did try a smart install via busy box to system/bin and installed open VPN binary to system/xbin. Are you using tun or tap? I am trying to tun and I have to keep installing tun driver after each boot and it crashes after disconnect. I tied two of he more poular openvpn apps. I have tried by ethernet, only WiFi.
                      I'll give it another go this weekend when I have more time.
                      Thanks for the suggestion.
                        1. i will enable tun support in next kernel build so you don't need to load it manuell.
                        2 please give me the down url for the latest busybox, i will update it in next firmware release
                        3. what is problem wiht netflix. please provide more infos
                        wasser
                          Originally posted by saddas View Post
                          Hi, wasser!
                          it's known issue, i'm working on it.
                          hardkeyboard issue is fixed! it will be included in next release
                          wasser
                            1. i don't understand your question
                            2. you can download from google
                            thanks for donation!, it's only used for new hardware, next coming rk32xx
                              Originally posted by safitocan View Post
                              hello community
                              can be a beast question:
                              can you get KITKAT on Minix neo x7 mini
                              the problem is that i don't have the hardware. I have asked minix to send me this hardware, but no response yet!
                              wasser
                                wasser
                                thank you very much for your response WASSER.
                                Merci beaucoup CHEF
