Originally posted by Pluto View PostAlso, no need anymore for Null Keyboard, recognized as Physical Keyboard, and i guess thats probably why i lost some features. The soft keyboard wont annoy you anymore.
Wasser, the Logitech K400 has three volume buttons, Mute, Decrease and Increase, located at F10, F11 and F12. I was wrong when i noticed it before since i did not put much time on it. What it seems to do is have just one option on the sound slider, its either absoluitely off or fully on, with just one click. As if the steps were removed, it used to be every click resulting in -+5% of sound, now its 100%. And if it crossed your eyes before, there is no sound output from the Headphone jack, and i mainly use that for my old HiFi AVR.
AVOUT is not yet supported in kikat-4.4.2
i uploaded new kernel again, could you please test if ethernet works?
thanks
just tested a couple of 1080p mkv's. Video quality is fine unless some powerful background movement on the picture is way too fast, very noticable. Drastic changes in the video also screw the quality, and every 10 seconds there's a buffering symptom (lag) followed by a resume with a quality decrease until it finds itself back.
Not for movie watchin yet, but ive streamed through Wifi. The wifi can definitely handle it, but right now it's serving 5 heavy users, and airtime can dictate quality a lot. I may see different results over Ethernet.
Tested with 1080p@60hz, DPI changed to 200.
Originally posted by wasser View Posti have tested some extern usb keyboard, it works for me.
thanks
http://www.freak-tab.de/wasser/kerne...-x7-090114.zip
PS, flashing on the way. Also, i am having a weird red flash all around the screen, but only around, taking around 100 pixels. It comes up after a small lag, what is that?
Originally posted by Pluto View Postjust tested a couple of 1080p mkv's. Video quality is fine unless some powerful background movement on the picture is way too fast, very noticable. Drastic changes in the video also screw the quality, and every 10 seconds there's a buffering symptom (lag) followed by a resume with a quality decrease until it finds itself back.
it looks like that wifi is not quick enough for fullhd video! please try the new kernel. I hope this kernel really fixed the ethernet issue
Originally posted by Pluto View PostNo no, it's a basic AUX cable, all analog, it does not differ from a headphones at all, i remember listening to music on a KitKat phone :P.
Guest
Wasser, Very nice and very close already. I'm using a minix neox X7 using your 090114 kernel and other base rom items that you included in the original post. Some testing results: - The volume issue mentioned before by Pluto in #30 with only one stop of full on, full off or mute happens on other keyboards as well as the previous post stated Logitech K400r, I tried on a favi rf keyboard and had the same issue, - No Ethernet still with the new kernel, - CBS, ESPN and Verizon Fios now work with this fw, instead of the crashes that I was getting when using minix 008 fw and finless 1.8 fw, - NBC and ABC apps (which are 2 of the 4 major channels in the US) show as device is not compatible, - Showtime now shows an error that HDMI output is not supported but it did not show this under 4.2.2 fw's, - HBO GO playback is very choppy vs. prior 4.2.2 fw's. It seems like you are really close to overcoming the major issues that 4.2.2 had so great work. Let me know how I can help.Last edited by Guest; 10 January 2014, 01:33.
Guest
Originally posted by wasser View PostI have taken a look at both dmesg.Log. saddas Do you have minix x7? Your dmesg Log Shows differrent WiFi/ethernet drivers
Gesendet von meinem HTC One mit TapatalkLast edited by saddas; 10 January 2014, 00:09.
There are currently 1374 users online. 0 members and 1374 guests.
