What about sound routing with using MINIX NEO A2 airmouse?
Originally posted by mariocro11 View Posttemp solution i use, unplug usb wifi dongle when not using remote (watching show), sound returns to tv speakers. Sometimes when i plug it back in sound stays on tv, sometimes switches to remote. Can't figure out why sometimes it happens, sometimes don't.
And I found a new problem.
When I need to watch a video online if I did not immediately go into full screen mode, but only after I press the play button of the video and not in another, then I see black screen but with sound. If you go back to page view mode, video window crashed (colored lines) when the page refresh, you can run the video again.
Originally posted by EagleEyeXZ View PostI will test next week did you make more changes for audio passtrough?
Originally posted by jmcm View PostHi wasser,
It's about the same results as before.
In Kodi 16.1 passthrough works but with brakes every 2 or 3 seconds.
In Spmc 16.2 hwg, just static.
In Ftmc and Rkmc, no sound at all.
Here are the logs:
https://dl.dropboxusercontent.com/u/...45/logsV306.7z
reboot it and test again
thanks
Ok this latest 3.06 fw + OC kernel is fantastic!
Completely stable and very fast till now
Video playback on kodi 17 is still choppy
but on 16.1 is flawless
I don't use any amp so I don't know what happens with audio passthrough
I was about to sell my minix but this fw saved it
Thanks Wasser !
Originally posted by flhthemi View PostWell for those UT2 owners that were wondering this ROM will install! It will also let you install Kodi Krypton 17RC2!
What it won't do (for me anyway):
Ethernet connection seems to drop in/out randomly
Bluetooth seems to need WiFi enabled for it to not lockup the device I also was able to pair it with some headphones, but no audio through them at all.
Sound is working via HDMI but I couldn't get anything from the stereo output. Don't know about passthrough for 5.1 (didn't hook it up to my amp and TV) or via SPDIF.
The UT2's remote is totally non-functional
So...at least I can still use it for Kodi which is all I really wanted but we'll see how that goes as I just installed it and am setting it up right now.
Big Thanks to Wasser! You did it again!
EDIT: Just discovered I flashed V3.03Well, back to the drawing board for 3.04...tomorrow.
So glad Wasser is still plugging away for for devices, I now have Wasser firmware on 3 different devices.
Installed 3.0.6, kodi 17, custom build(graphics heavy), addons, tried 720p 1080p rewinding, skipping, forcing it.... all that came to mind, tested for 30-ish min and it works great, didn't crash, stabile, that minix airremote thingy works, sound on tv from the start, no tweaking or messing around. Works perfect, for me at least. Great work wasser, really great work, biiiiiiig thank You.
There are currently 2810 users online. 1 members and 2809 guests.
