This was 3.0.5, though. There is always the slight possibility that Wasser has misconfigured the oc'd kernel for 3.0.6.
Originally posted by Pluto View Post
This was 3.0.5, though. There is always the slight possibility that Wasser has misconfigured the oc'd kernel for 3.0.6.Last edited by Molle; 21 March 2017, 16:45.
Originally posted by Pluto View PostDid you by any chance change minfreq? was it sticky on the previous version?
Originally posted by Pluto View PostNothing sticks.
Originally posted by Molle View PostLike I wrote earlier, I had to use RkDevelopTool to flash the kernel. No flashing method used from within the system worked.
I have used the same tool, loaded it on the separate partitions tab, wrote 0x0000E000 for kernel, and it wrote it successfully. I even loaded the ROM with the same tool on the different tab, am wondering if the kernel can be loaded the same way.
P.S. 1k post
Originally posted by Bazmamfoo View Post
I can't tell if you're actually being as rude as it seems or if it is only because your English is so bad, but you need to STFU. All you've done on this forum is ask for help on this ROM (which you've gotten) and then bad mouth people who compliment wassers work.
I don't know where you're from but that's considered bad manners anywhere I've ever been.
Originally posted by Molle View PostI have never done it that way. I've always used just the "Flash" tab, unticked everything except kernel, located the kernel image and hit "Run".
P.S. 1k post
Would you mind showing me a link of the RkDevelopTool you use?
Originally posted by Pluto View PostWould you mind showing me a link of the RkDevelopTool you use?
we need fix app for v3.0.6
- AirPin Pro 3.3.3 Minix not connected for other device
-app RKRemoteControl not see Minix ... i think need something for "ehome media center "
- when use micracast app = restart system
also default remote minix x7 not workLast edited by nayef; 25 March 2017, 10:42.
There are currently 2618 users online. 1 members and 2617 guests.
