Originally posted by Mario023 View PostLook at post #2279 type one of those lines into terminal emulator
Than press enter and reboot or?
In case of OC kernel, you have too use an app to modify min/max frequencies... if you see 1800hz.... you have taken good direction ;-)
hi i have noticed lately that when listening through optical cable to my amp the sound drops breifly every now and then. i have tried the different sound settings and screen settings. happens in both kodi and youtube app. no problem when listening through hdmi to my tv. used to be ok i think, only happened in last week or so
i think i found my solution. when i have the sound passing through my tv then to the amp i dont have the sound drops. this must be how i used to use it. it only drops if i have the sound going direct to the amp from minix
dear wasser
the last update(2.03) is very fast for me
also and the wasser spmc mod version of yours(1.03) is very good(maybe the best for me)
although i have a little issue with the WifiDisplay.apk
when i extract the system.img i see the app in the app folder but this app is not installed
i also try to install it as application(WifiDisplay.apk) but also is not installed at the end
any help is appreciated!
thank you!
There are currently 2675 users online. 1 members and 2674 guests.
