Originally posted by Kiralina View PostCheck page 93 post 1851 of this topic.
why?there is an other program with i can flash the kernel?
rkandroid continue to say "no found rkandroid usb"....
this thing drive me crazyyyyyy
Originally posted by xmnemox View Posti'm going crazy.... i can't flash kernel with stock kernel... rkandroidtool 1.37 can't find my minix, rkbatchtool does and flash the rom without problem......
1.Download any terminal emulator from google playstore
2.Rename the kernel you want to try from the kernel pack kernel.img
3.Copy kernel.img to the root of internal sdcard (use included ES Explorer)
4.Open terminal emulator and type these commands:
su
flash_image kernel /sdcard/kernel.img
There is a space between kernel and /. Don't miss it !Minix Neo X7 - Wasser 1.0.4 OC'd - Kodi-helix with passthrough
Beelink M8B - Wasser 1.0.3 - Kodi-helix alpha 2 + SPMC
su
it says
wrote kernel partition
Originally posted by xmnemox View PostBut i hAve always The same problem...
gmail has unforuntely stopped....
and i can't trash The widget on "desktop"
Try wiping the apps data > reboot > try again
If you still have issues try a clean install of 1.0.4 it has stock kernel. Also if you clean install when it boots for first time let the device stabilise for 5 mins before playing around.
Good luck.Minix Neo X7 - Wasser 1.0.4 OC'd - Kodi-helix with passthrough
Where can I download Molle's boot image?
Originally posted by Kiralina View PostThank you guys.
Wasser's KK 1.0.4 with Molle's boot image and OC kernel config. + Karel's Kodi-Helix seems to be the winning combo for me.
Played fluently blue ray iso (from external media drive) with dts 5.1(optical). And no more endless buffering in xbmc when watching online movies.
I have almost gave up on my Minix (and in general on android TV boxes) and was thinking of getting a Lenovo Q190 with i3 processor, but now I think I'll save the cash and keep the Minix.
Anyone please advise on this?
Originally posted by Koshara View PostOne more quick question folks - is there a way to enable/configure daydream/screensaver/standby function in this firmware? In short - I'd like my box to go black screen in a minute of inactivity and go to standby in 10-ish minutes (if possible at all).
There's a Daydream section in options, but it doesn't seem to work in any configuration (clock/photo frame) and with any pre-defined timeout.
Your advice please?
Thanks!
There are currently 2813 users online. 1 members and 2812 guests.
