Coolio
What can i say. brilliant job man.
suddenly the true potential of this box has shown its face!!
- smooth 1080 streaming
- super fast responses
- the picture on screen is vivid!!!
- network very fast
great job wasser.
Is there any chance of fixing the analog min audio in?
is there a recommended xbmc version with hw decoding? (any i've tried suffer from major stuttering)
- network very fast
great job wasser.
Originally posted by finov View PostWhat about stock remote control, Wasser?
http://www.freak-tab.de/wasser/kernel-minix-x7-160114.zip
Originally posted by Batfink32 View PostIf you use the app `Full Screen` from the Play Store it will remove the Nav Bar.
Sent From My Nexus 7 (2013) Using Tapatalk
Thanks.
Re: KitKat-4.4.2 for Minix X7
Originally posted by kbgbef View PostBatfink32, are you referring to the app full!screen - https://play.google.com/store/apps/d...orn.FullScreen ? I ask because one of the reviews on the play store says that it doesn't work on Kit Kat.
Thanks.
Sent from my Nexus 5 using Tapatalk
Originally posted by wasser View Postplease try this new kernel, it supports stock ir-remote
is yes please keep update log on the first post so we could be notified. Thanks
http://www.freak-tab.de/wasser/kernel-minix-x7-160114.zip, thank you, you are the best, Wasser
Originally posted by brezix View PostOnly 1920x1080 /24 is OK. Any other 1920x1080 /50,60 have problem.
There are currently 1789 users online. 1 members and 1788 guests.
