Blacklist of locked Down Version´s of RK3188 CPU
As fare as I read, it is an underclocked s600 1,5 GHz inside and you can overclock the snapedragon, but thats not the point.
You don't need it. The nexus 7 is really fast enough. Spare better your battery.
Before I want something to change, I have to find the failure first. :-) and I have the device since 4hours.
JDfense ----> Nexus 7 ▶ 2013Last edited by JDfense; 13 February 2014, 08:54.
Originally posted by digger View PostDear d33,
But how then can you explain that I have been shown with 1,6 and 1.8Ghz using 4.2.2 wasser FW(ver.1.2.4) +Sam's overclocked kernes? In addition the stock 4.2.2 FW shows me 1.6Ghz too?Measy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Originally posted by dracosc22679 View PostUntil we find a solution for our T models, is there any way to just overclock GPU and RAM? Also....how can we check the current GPU and RAM frequencies?
for overclock T models you can run neomod 1.7 + SAM overclock
or neomod 2.1 + SAM overclock
example: http://www.freaktab.com/showthread.p...l=1#post138100
Originally posted by d33 View PostKernels created with source code from before the T variant existed don't have code to detect and limit it, kernels created with source after the introduction of the T chip do have code for it. I explained in #329
Ram operation 2248; Perfect
Ram Speed 967; Low anough
GPU 2D 1398; Extremely Low
GPU 3D 2104 Extremely Low
Total 19507 Perfect
while mali_dfvs shows me this strange row:
128,179,223,297,297,446
where 297 is doubled and 446 is upper value, when I know it must be at least 597.
Probably there is something else we don't know about, like GPU and part of RAM (which seems to be as videoRAM), adjusting process.
What would you say about it?CS918II/16GB(HTC-031-V1.0 board)
CS918 (TN-BX09_V2.1 2013/05/31) FW: k-r42-old_revision-wasser-1.2.3- fried by 12V PS
K-R42 board version B351_V2.0 1348, wifi Realtek8188ETV , RK3188T;FW: wasser-firmware-kr42-new-1.0.3
Originally posted by stubuchy View PostI think they are all the same chip... BUT some pass the stress tests and others don't, those that dont are locked at the lower speed and market -T, obviously some of the chips that pass the test will also go into the -T pile to make the numbers up when not enough failures, so you will find that some over clock and some don't...
Same as Intel, in the old days they were are fabricated as the fasted chip and then graded, the ones that qualified for the top speed were used as that, then they were graded down from there and sold as different speeds, but some basic models were able to clock back to an amazing clock speed as they had to use the best chips to make the numbers up of the lower speeds, some were not able to as they were the failed ones...
luck of the draw unless you use a quality manufacturer that has decided to use non -T's like MiniX, mine clocks to 1800 without an issue and is very fastyou pays your money and you get what you pay for.... unless you were lucky
simply go get the non-T, easy.
Originally posted by digger View PostThanks d33, I understand you, but in case I flash my device with 4.2.2 FW + "old" Sam's overclocked kernels I have CPU dfvs tables with 1600, 1704, 1800... with increased CPU performance and total 19500+ score in accordance with AnTuTu (4.0.X), but at the same time something wrong with part of RAM and GPU performances, because I have:
Total 19507 Perfect
What would you say about it?Measy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Originally posted by kenofstephen View PostNot really wise to BET on something you paid actual money for (not monopoly's paper money),
Or not so easy.... So far the only manufacturer that I know of that is not going to use the T model is Minix... are there others that you know of besides Minix.
I'm only asking for other people really... personally I don't mind paying for higher quality parts like Minix seems to provide. I already have a NEO x7 on the way for my own use.
Originally posted by d33 View Postpost the kernel here
Diese Website steht zum Verkauf! cloudstor.es ist die beste Quelle für alle Informationen die Sie suchen. Von allgemeinen Themen bis hin zu speziellen Sachverhalten, finden Sie auf cloudstor.es alles. Wir hoffen, dass Sie hier das Gesuchte finden!
and the thred where it was from:
The AnTuTu and dfvs information in my previous message correspond to 720p 1.8ghz ram 1500mhz kernel.
Please don't pay your attention that kernels had been tested were compilled for sticks and didn't support my onboard LAN. The main idea was to test overclocking ability only.
Thank you very much for your friendly intention to help meCS918II/16GB(HTC-031-V1.0 board)
For KitKat ROMs only
Here is a kernel that will output to DMESG the chip type and will overide the 1.4 GHz limit for T chips to 1.6 GHz
Kernel is AP6210 standard wifi, 1.8 GHz (1.6 for T models), 1080 resolution, 720 DDR, 600 GPU
I have tested on a 'standard' RK3188 and can confirm this boots and outputs the message to DMESG but can't test the T overideAttached FilesMeasy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Re: Blacklist of locked Down Version´s of RK3188 CPU
Kernel is 1.8 GHz (1.6 for T models), 1080 resolution, 720 DDR, 600 GPU
Btw, is it possible to get 720p kernel? Not now, but if this will work.
Sent from my Nexus 5 using Tapatalk
Sent from my Nexus 5 using TapatalkAttached FilesMeasy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
There are currently 2223 users online. 1 members and 2222 guests.
