Blacklist of locked Down Version´s of RK3188 CPU
Originally posted by JDfense View PostMaybe the boot loader is connected to the T-models hardware and the imgs have a new connection to the boot loader.
We should search in the imgs for new files or hidden files.
Or we ask the N.S.A. They know most of the secrets around the world. :-)
JDfense --->I8160
When I get my stick trust I will DIVE DEEP into this BS....
Originally posted by Finless View PostI have a stick coming with a 3188T and I will be studying all this.
Up until now I had no way to see what everyone is talking about.
I received a "CX919 II" this morning. The CPU frequency is restricted to 1416MHz and the signal from the HDMI is frequenctly dropping at 1080p. This is the stock build; it defaults to 1920x1080 and 'flickered' right out of the box. My money is on whacky HDMI timings.
Let me know if you want me to post android and/or kernel build strings, dump a system img or crack the thing open to take pics. I bought it with the intention of installing Debian and using it as a server, so display problems aren't a biggy, but if I can offer any useful info, do ask. I received a power adapter with a flaky USB jack so I'm not going to risk flashing anything until I have bought a safe power supply!
Nathan
I'd like to note that there are at least two different problems with new minipcs.
1) Not overclocking or overclocking with some hacks (probably all minipcs). Even if overclocking works (as on my mk902 to 1.6ghz) the problem with blinking is usually not resolved.
2) Blinking - from which suffers only some minipcs and depends on mutual combination of minipc HW, kernel and monitor (after trying on more than 10 monitors we vere able to find monitor without blinking on two otherwise heavy blinking mk902). If there is blinking for some people may help just putting tv stick directly in tv hdmi port. For others may help playing with frequencies and so on. And the most heavier cases blink always except new stock roms (I posted one kernel from stock from cr11s and all the people so far confirmed that blinking is gone). If stock rom is blinkig than it is either witchout patches or the minipc is out of hw tolerancy at all.
So that in my opinion in these stock kernels must be some new patches or changes in configuration. Some change in linux kernel sources, used by manufacters to produce their stock kernels, and not known publickly in community. My guess.
Regarding lack of access to higher CPU clock frequencies, see this commit: https://github.com/linux-rockchip/rockchip-3.0/commit/66664e64963f1e0b6a888397beb1d2baffcb29d8
So, it is not really a problem per se, but rather an intended limitation. The problem is we're being sold lower-grade parts (i.e. RK3188 parts that have failed QC and been binned as the RK3188T) without being informed. I would not expect that most RK3188Ts will just as reliable at 1.8GHz as the RK3188 can be; fashing an alternative kernel does not make inferior hardware better. Notice also how some software will still report 1.6GHz max. The SoC still presents as a normal 1.6GHz part in userland, but the kernel knows otherwise.
Rockchip are either a) incompetent b) devious or c) both.
Originally posted by unaszplodrmann View PostRegarding lack of access to higher CPU clock frequencies, see this commit: https://github.com/linux-rockchip/rockchip-3.0/commit/66664e64963f1e0b6a888397beb1d2baffcb29d8
In fact, given what Gianca90 reported here:
Originally posted by Gianca90 View Post...I noticed that the neocrom 1.9a use the 2.07 Loader as the neocrom 2.0... In that case overclock is always not working; for example I tried to make an overclocked version of the neocrom 2.0 kernel; and If I use a kernel with cpu over 1.6ghz ì... the cpu will run at 1.2ghz... or If I use a 1,4ghz cpu kernel or above it will run at 1.2 - 1.4ghz -.-
IMHO I think that the problem is related to the compatibility between Loader 2.07 and overclocked kernel? or sam overclocked kernel???
With the crom 2.1, or finless 1.6b or Hybrid rom 1.7, wich uses LOADER 1.24 (or 1.20), the overclocked kernel works with any frequencies you want! But there is the flickering distorting problem (and the screen disappear and re-appear with the hdmi cable), so you have to connect the stick direct to the hdmi port.
Originally posted by neomode View PostTry the Neomode Hybrid Rom 1.7 with Sams Kernels. This should Work for Your Device.
Neomode
Gesendet von meinem GT-I9305 mit Tapatalk 2Mk802IV Neomode 1.9a original rom 720p
Update about
Here:http://www.freaktab.com/showthread.p...l=1#post139253 I wrote about nice pare Finless 1.6b CX 919 with SAM 1080p Kernel - CPU @ 1.8GHz, RAM @ 1.2GHz on my RK3188-T
Antutu was higer then 19000
Today I tryed to install Neo1,7 + same kernel (SAM 1080p Kernel - CPU @ 1.8GHz, RAM @ 1.2GHz)
Antutu crashed stik on 30% of runing test. Strange.
I installed Finless 1.6b CX 919 with SAM 1080p Kernel - CPU @ 1.8GHz, RAM @ 1.2GHz back. Same result. Antutu reboot stik on about 30% on a runing test.
Very Strange.
I were go back to Neo1,7 + SAM 1080p Kernel - CPU @ 1.8GHz, RAM @ 1.2GHz
But no - reboot stik on about 30% on a runing Antut test.
Then I run movies about 2 hours, all was smooth without any issues
So it seems that is all good, but only Antutu problem now.
I took the case off, there was a hot spot on the not very efficient stock heat sink. I let it cool and set the clock back to 1800Mhz. With the case off, Antutu completed with a score of 19842. I placed a fan so it is blowing on the heat sink. Antutu scored 19937.HK1 Pro Plus
FlowFon F1
H96 Pro+ (Wisdom-Green Board-2017-02-10 H96-S912-TVBOX(DDR4)-V0.2)
MXQ Pro+
R-TVBOX Mini+
MK809III
I am currios when was the last time when rikomagic or somebody else publiced the fresh source codes. Or do producers public their source codes reguraly commit by commit?
Clearly states 3188 chipset . IF shipped with 3188 its clearly being faulsly advertised and re sellers in China can address but
But only once they are made aware of it. Geekbuying has told them to market as 3188T other reputable suppliers will follow same path.
Bob i still laughing at safety video!!!!!!!!!
Very Strange.
There are currently 2337 users online. 1 members and 2336 guests.
