Blacklist of locked Down Version´s of RK3188 CPU
Originally posted by rdsok View Post
There was a compile error in the files uploaded which means the override wouldn't have worked, I've fixed and re-uploaded. Apologies to the few who downloaded already.Measy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Originally posted by norbert6 View PostWould this kernel work on any rk3188(t) devices? Always thought the kernel is device - specific...?
The kernel itself is equivalent to the one in Bob's Kitkat Beta ROM 2.0, so MK908 etc compatible.
If you are already running KitKat then just flash this kernel on, read the DMESG, check the CPU range, report back on here and then, if this kernel doesn't match your kit, flash back to your 'normal' kitkat kernel.
This is for experiment only.Measy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Originally posted by JDfense View Post@d33
No, sources for jellybean T-kernel, you said?
JDfense --->I8160Measy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
mk802
I just noticed that official Rikomagic web page (www.rikomagic.com) is constantly updating the specification of their devices. The last one is real curious:
Rockchip 3188 Quad core, 28nm, 1.4GHz , Up to 1.6GHz,Cortex-A9
Originally posted by norbert6 View PostOkay, tested the kernel with my mk908ii, 3188t.
In 1080p I get 17400 points in AnTuTu and the overall performance seems to be much smoother
Will also test 720p and wifi speed later.
Thanks for your work d33, really appreciate it
1. Within Antutu go to the Device Info page and check the CPU Speed to confirm increase to 1.6 GHz.
2. Open a terminal emulator and check that RK3188T is detected and output into DMESGMeasy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
AW: Blacklist of locked Down Version´s of RK3188 CPU
AnTuTu score on 720p is 18200
Do you think heat is a problem with this clock speeds? Don't have a custom heat sink and don't want to burn my device
Wooooo dude THANK YOU SO MUUUUUCH
1.6GHz and my dongle is cold after MKV movie HD 720p !!!!
I try the 1080p later but all seem to be good excepted I have to tweak my lost wifi connection at first boot(password).
Nice logo Android TV
GK525 here RK3188T
Originally posted by valzja View PostI have CX-919 v2.0 device I will test later, hopefully it will work.
Sent from my Nexus 5 using Tapatalk
Also I can build test builds at 1.7 and 1.8 GHz if there is interest?Measy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
There are currently 4252 users online. 0 members and 4252 guests.
