Sent from my Nexus 5 using Tapatalk
Blacklist of locked Down Version´s of RK3188 CPU
ok, thanks to Norbert's testing we can see I have an answer for RAM and CPU, I just need to work out the GPU throttle. Thanks Norbert!
Norbert6's device has a leakage level of 4000 and is stable up to 1.7 GHz
Would be great to build up a picture of stability vs leakage level as I could then write code to auto-set frequencies to matchMeasy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
AW: Blacklist of locked Down Version´s of RK3188 CPU
Originally posted by d33 View PostWould be great to build up a picture of stability vs leakage level as I could then write code to auto-set frequencies to match
Why do you think 1.6ghz failed? After a short time the screen "freaks out" and I had to cut power connection to reboot...
I think we have an answer!
Present for Norbert > 1.7 GHz kernel with 720 DDRAttached FilesMeasy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Re: Blacklist of locked Down Version´s of RK3188 CPU
Originally posted by d33 View PostThe 1.6 GHz build used reduced voltage to see it that made more/less stable.
Originally posted by mikele View PostJust a little concern...
If my device do not start with 1.8GHz kernel, do I have to reset it ? Or that's will be OK with romflashtool ?
If you are not comfortable doing this then I recommend not. Play safe!Measy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Yepp
Sent from my iPhone using TapatalkMeasy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Originally posted by valzja View Postd33, sounds very good, I can't wait until I will be home and test, but can you build this in 720p version?
The desktop SHOULD just rescale. My kernel has Rockchip's faulty EDID fixed so it should read your TVs capability. So on my TV it presents a 1920x1080 desktop to my TV at 1080p60. On a TV that can 'only' do 720P60 (50) then it should scale the desktop to the HDMI.
If it doesn't then let me know and I'll build more but it shouldn't be necessary. Certainly not for this quick test.Measy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Originally posted by mikele View Post1.7GHz no boot just googleTV and black down so I hink its useless to try 1.8GHz right ?
GK525 RK3188-T-
Can you post your DMESG for the standard kernel if even this doesn't work and we can add your result/leakage level to the list.
Ta!Measy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Ta!
Originally posted by mikele View Postfor now I use your 1.6GHz 1080p for my gk525 RK3188-T and thats run like charm so its useless to try 1.5 right ? My dongle stay cold and run perfectly at 1.6GHz
Please post the DMESG from the 1.6 build. As a reward I might build you a 1.6 override with faster RAMMeasy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
There are currently 3034 users online. 0 members and 3034 guests.
