I have 3188 without T, but it works as T 1.4Ghz. why?
Blacklist of locked Down Version´s of RK3188 CPU
Hi d33,
Would you be so kind to teach me how I can take eFuse dump for my "T" 3188. If it is possible by using some terminal commands with your short explanation.
I could not stand with such kind of fraud (when they have 3188 in specification but ship us "T" in fact)and have my dispute with my Chinese seller been opened.
I need more evidence because I cannot remove heatsink and only one thing I have as evidence is AnTuTu screenshot line with 312-1416 specified.
ThanksCS918II/16GB(HTC-031-V1.0 board)
CS918 (TN-BX09_V2.1 2013/05/31) FW: k-r42-old_revision-wasser-1.2.3- fried by 12V PS
K-R42 board version B351_V2.0 1348, wifi Realtek8188ETV , RK3188T;FW: wasser-firmware-kr42-new-1.0.3
Originally posted by ma_trix View PostI have 3188 without T, but it works as T 1.4Ghz. why?CS918II/16GB(HTC-031-V1.0 board)
As stated by others may be a T chipset did you open the unit or thats what they told you you have?Many devices now mk902ii/Shield/Mk68 /Ugoos/neox5/minix5 (yes they still work lol) mk80 no it doesnt work lol.
That shows nothing you would have to pull off the heat sink and check the CPU, or run d33 check on it as normally damage to board getting heat sink off unless you know what your doing. Version 3 main board and your saying locked at 1.4 so I think you got T chipset, but only two ways to check run d33 check or remove heat sink.Many devices now mk902ii/Shield/Mk68 /Ugoos/neox5/minix5 (yes they still work lol) mk80 no it doesnt work lol.
Originally posted by ma_trix View PostI was checking the processor without the heatsink, the processor is no T.
If you'd run the test that has been suggested a few times now... you would know more.
I'm still not sure why you'd post a picture of the CPU with the heat sync still on it IF you had actually removed it at some point... it was a useless picture to post if it wasn't one of the CPU itself.
I hope he does test it and if its not the ROM locking it would confirm a thought finless had on same that maybe even some of the 3188 had been locked by rockchip? Would explain way so many boxes dont install roms other then stock.Many devices now mk902ii/Shield/Mk68 /Ugoos/neox5/minix5 (yes they still work lol) mk80 no it doesnt work lol.
what model do you have? What ROM are you using? Post your DMESG output.Measy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Originally posted by d33 View PostFor KitKat ROMs only
Here is a kernel that will output to DMESG the chip type and will overide the 1.4 GHz limit for T chips to 1.6 GHz
Kernel is AP6210 standard wifi, 1.8 GHz (1.6 for T models), 1080 resolution, 720 DDR, 600 GPU
I have tested on a 'standard' RK3188 and can confirm this boots and outputs the message to DMESG but can't test the T overide
Yes having the dmsg and Rom build if locked at 1.4 will be interesting to see. Why if in chipset then the rabbit hole just got deeper.
Ma_trix
If possible can you do as D33 asked and post very interested in those results.Many devices now mk902ii/Shield/Mk68 /Ugoos/neox5/minix5 (yes they still work lol) mk80 no it doesnt work lol.
Re: Blacklist of locked Down Version´s of RK3188 CPU
@finless, have you had a chance to play around with your MK908ii with the 3188T yet? I've ordered one, awaiting delivery, and would love some feedback on which ROMs work without flickering, overheating etc.
Otherwise I guess I'll be stuck with stock
There are currently 2038 users online. 1 members and 2037 guests.
