We speak about 6210 1080p/720p right ?
Blacklist of locked Down Version´s of RK3188 CPU
AW: Blacklist of locked Down Version´s of RK3188 CPU
Originally posted by neomode View PostNo wonder they all came from the same manufacturer
Only a different Brand.
Neomode
This would be a nice move after making a very good business. ;-)
JDfense ----> Nexus 7 ~ 2013
Re: Blacklist of locked Down Version´s of RK3188 CPU
Originally posted by d33 View PostLeolas, they are both DDR tables as explained above.
Table 8 is DDR for RK3188
Table 9 is DDR for RK3188T
But, again, don't use that kernel use the special kernels provided in #614
leolas.REMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
Hi neomode,
Can you share your positive experience with init.rc patching?
I tried to repack my stock boot.img and do changes in init.rc, but don't have any success with mali_dvfs.
It always shows me the same:
<4>[ 6.793369] Mali: mali freq table :Mali: 128,Mali: 179,Mali: 223,Mali: 297,Mali: 297,Mali: 446,Mali:
Could you give us short example with your GPU dvfs table No7 and your changes in insmod/.../mali.ko... line?
Thank youCS918II/16GB(HTC-031-V1.0 board)
CS918 (TN-BX09_V2.1 2013/05/31) FW: k-r42-old_revision-wasser-1.2.3- fried by 12V PS
K-R42 board version B351_V2.0 1348, wifi Realtek8188ETV , RK3188T;FW: wasser-firmware-kr42-new-1.0.3
Thank you
What Neomode found was a ROM that simply had no 600 frequency specified.Measy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Originally posted by mikele View PostThere is no table 9 in this kernels in #614, is it normal (I need to patch for "T" models) ?
Kernels built directly from the KitKat Beta sources have 2 DDR tables; one for RK3188 and one for RK3188T. The CPU is locked to 1.4 GHz if it is a "T" spec regardless of the values in the CPU table and the GPU is throttled regardless of the values in the GPU table if it is a "T" spec.
I have created 'special' kernels that remove the dual operation. The CPU and RAM will operate at the frequencies in the table regardless of whether RK3188 or RK3188T. The only limitations still in place are that the T CPUs are frequency capped (usually to 1.35V) and the GPU is throttled.
So in the #614 post the Kernels have only one 'universal' RAM table (table 8).Measy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Just wondering
Ok, I've been trying to read everything in this thread, and a few conundrums keep popping to mind...
1. You guys do know that you can use the serial port on these sticks to access the console, and effectivly check that the stick crashed, or if it was just some android ****up which has the system in an infinite reboot cycle. I mean, the stick is accessible without any tv attached, when you have the serial console. I wouldn't be surprised if you could also get telnet or ssh access with a little tweaking.
2. regarding the frequencies.... CPU and GPU are both in the same package. RAM is external.
so if an RK3188T is one of the "not so qualitative batch", then it's fair to assume that overclocking it will be problematic, not for all, but definitively for some. Add to that the RAM, which we can assume isn't the best grade as well. and all of this thrown together, just brings out a whole mess of working and failing frequencies.
So, make a small tool that is able to adjust the frequency tables, for the cpu, gpu as well as ram, in memory and testing it will be as easy as running a script for a long time.
3. three
nJoy !
Ugoos UM2 only stick with Non-RK3188-T?
I'm not sure this information is relevant here anymore, but just in case for people looking for Non-T Stick.
I was finally able to learn a little bit, and able to run Dmesg on Ugoos UM2 I recently purchased.
And I think test result shows non-RK3188-T if my understanding is correct. I appreciate one of devs can confirm it.
I bought it from Geekbuying fulfilled by Amazon in USA, and received on Feb 13th, 2014.
Again, it still could be from old stock, so I cannot say all UM2 still uses non-RK3188-T.
Please don't blame me if you get RK3188T for future purchase.
Here is copy of Dmesg
<4>[ 0.711778] efuse_version_val: efuse version = 31
<4>[ 0.711817] DVFS MSG: core: dvfs_adjust_table_lmtvolt get leakage_level = 3000
<4>[ 0.711872] adjust table freq=1800000 KHz, index=1375000 mV to index=1350000 mV
<4>[ 0.711928] efuse_version_val: efuse version = 31
<4>[ 0.711965] DVFS MSG: aclk_gpu: dvfs_adjust_table_lmtvolt get leakage_level = 3000
<6>[ 0.712847] CPU is ROCKCHIP RK3188
<4>[ 0.713145] rk3188 cpufreq version 2.2, suspend freq 1200 MHz
<6>[ 2.130143] ddrfreq: verion 3.2 20130917
<6>[ 2.130173] ddrfreq: fix cpu pause bug
<6>[ 2.130201] ddrfreq: normal 720MHz video 300MHz video_low 0MHz dualview 0MHz idle 0MHz suspend 198MHz reboot 300MHz
<4>[ 4.879490] Mali: Mali400 inside of rk3188!
<4>[ 4.879522] Mali: mali freq table num : 6
<4>[ 4.879653] Mali: mali freq table :Mali: 128,Mali: 198,Mali: 256,Mali: 297,Mali: 384,Mali: 594,Mali:
<4>[ 4.880283] Mali: init mali clock success
<4>[ 4.881642] Mali: Mali device driver loaded
Used Finless Kitkat with d33 very first kernal posted on this borad.
Thanks to all devs here helped me to choose good stick especially, el_easy, d33, and Bob
Originally posted by weirdow View PostOk, I've been trying to read everything in this thread, and a few conundrums keep popping to mind...!
2. PHJAnderson has created a patching script - see the link above for my amendments for KK beta kernels.Measy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Originally posted by taikanaumi View PostDmesg on Ugoos UM2 I recently purchased.
And I think test result shows non-RK3188-T if my understanding is correct.Measy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Originally posted by d33 View PostThe kernel code in KK beta throttles the GPU. I think I've got it but have nothing to test on at the moment. I may have just received a 'T' CPU TV box at home though. I'll find out when I get back on Friday.
And one more interesting thing is that there aren't two lines with CPU/GPU leakage level=2, when I use sam's old kernels but the rest from stock 720p FW.
I would like to check if it is possible to OC GPU like neomode did, but I expect I do something wrongly.
Which box model is waiting for you at home? I would be happy if it were K-R42/MK888CS918II/16GB(HTC-031-V1.0 board)
Originally posted by digger View PostWhich box model is waiting for you at home? I would be happy if it were K-R42/MK888Measy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Originally posted by d33 View PostBegins with Cx (CX-921??) - it's a new model for testing. I'm assuming all new RK3188 stuff except Minix are "T" spec
And if it is not BT version, you'll have strong Realtek8188 wifi inside who is the best 150mbps chip on my opinion.
The main difference from my K-R42 box is your one won't have SPDIF audio and external antenna, but have MIC.
When you will think how to open the case of box, ask me and I send you photo with the latches positions.CS918II/16GB(HTC-031-V1.0 board)
There are currently 3624 users online. 1 members and 3623 guests.
