Blacklist of locked Down Version´s of RK3188 CPU
Actually ARM is little endian and so I'm talking rubbish!
Let's wait for bob to disassemble
Sent from my iPhone using TapatalkMeasy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Stuck at 1.4Ghz no idea why
Originally posted by vxxozxxv View PostI have an MK908ii that states it uses the full 3188 chip. I have checked with the software utility provided by NEOMODE and it says full 3188, and I also checked the DMESG output from my device, nowhere did it list 3188t. I'm not comfortable removing the heatsink. I tried all the ROM options from D33 in post #614 but none of them worked. The 1080 would never load, just a black screen, and the 720 would show two vertical white lines. I'm using Finless KitKat ROM. When I load the over clocked kernals provided by Finless BOB I'm able to only get to 1.4Ghz, stock ROM is only 1.2Ghz.
Any ideas on what is going on with our setups here?
Thanks for the help.
Does anyone one else have this same issue? I do not have the low end T series of the Rockchip 3188, but still can only over clock to 1.4Ghz with the use of kernel that's spect at 1.8Ghz provided with the KitKat ROM by Finless Bob. The Kernels provided by D33 do not work for my MK908ii at all.
I'm looking for what to change to get the higher performance that I should have, 1.6Ghz.
Thanks.Minix X8-H Plus - Finless Bob ROM 1.1 / GB Tronsmart MK908ii - Finless Bob 2.0 Beta KK ROM, D33 v300 OC
Originally posted by vxxozxxv;I do not have the low end T series of the Rockchip 3188, but still can only over clock to 1.4Ghz
Thanks.
Using my ipad so apols for any stupid ios spelling 'corrections'Measy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Originally posted by mikele View PostHey d33
You said about GPU " I think I got it".. so now my duckT is waiting
lol
You won't find much difference when I do though. Performance is improved most by RAM frequency
Donate to Finless
About memory... There is two Elpida DDR3 memory chips inside my GK525 key. The Elpida J4208BFBG memory chips specifications is 9-9-9 DDR3 1333 and there is no any other "BFBG" specifications on Elpida website but I saw somewhere on the rkpatchomatic forum that this memory is certified to 800Mhz. In same time it seem to be better to overclock and run only at 667MHz only. Any clue about this is welcome.
Wait states. The faster you clock it, the more latency.
Donate to Finless
Originally posted by Lude View PostIs there any sticks with the original 3188 left still or have they all switched to the T model?
I was just on geekbuying.com and it looks like they're all T's now
Originally posted by d33 View PostWait states. The faster you clock it, the more latency.
Thresholds Are 533, 667 and 800
Donate to Finless
Originally posted by rdsok View PostIf you don't mind going with a box type... Minix x7 and x7 mini are RK3188's. I've read that the Ugoos UT2 is going to be but hasn't released yet. As for true stick types, I haven't come across one yet but I do expect them to show back up again... it's just a matter of when once word spreads enough that people know the T models are having problems keeping up.
There are currently 2744 users online. 1 members and 2743 guests.
