So you can see I didn't reach more then 1.6 with KitKat then.
Before I was playing with KitKat I had had some another tests under my 720p stock ROM but with overclocked kernels by Sam321.
In case of using his 720p 1.8Ghz kernel I managed to see 312-1800 in AnTuTu. Please look
But it was too unstable and rebooting every 3-4 minutes. This combination didn't show me any leakage level information inside dmesg.
There is as of yet no reliable way to test for the rk3188-T. It's in the works if you dig a little deeper. Sometimes reading 30+ pages of a forum will give you much needed insight into many things. Read, read, read.
It is on my list to do, eventually
Sorry not disagreeing with your comment just claifying as i know none that have tested the 3188 and been locked at 1.4 the T hower some will run past the 1.4 but not the reverse of what your saying. so there is a test to see if true 3188 is it will oc. The problem is getting the T to be shown without removing the chipset fan.
correrct me if i am wrong D33?
Trust me ive read more then just whats in this thread.
I've downloaded the Jelly bean sources, added RK3188T detection and compiled. However, I can't test
So, can a few of you test this kernel for me?
You will need a Jelly Bean ROM installed.
1. Flash my kernel
2. Tell me if it boots
3. If succesful so far, post me your DMESG
Hi D33!
I've tested your kernel, on IPPli Mars I2s -> loader 2.0.7 -> Neotv CROM 2.0, didn't boot!
I'm nearly sure this device is rk3188-T
Thanks for you work, and if you want i am at home today i can test more kernels!
Loader 207 isn't that Kitkat?
There are JB Roms with 2.07 and 2.08 bootloader for my cs968 and I use the 2.08 for KitKat, too. Strange but true.
No 1.xx bootloader will Boot a Jellybean Rom for my cs968. I mentioned this before. Maybe it is something to think about.
