Blacklist of locked Down Version´s of RK3188 CPU
    You can do it yourself - just patch it
    Donate to Finless
      I don't know how to do that !!!
        Here the Statment from Rockchip about the T Version of the CPU:
        Rockchip testing all stock of producing SoC's some stocks not passed tests for any reasons. Then RK cut the CPU and GPU frequencies for stability. And add an external frequency generator for LAN working. And call this - "low-consumption" version. In fact, it is rk3188 who not pass the tests.
        Now we know what we have!
        Neomode
          Now it is official garbage from Rockship:-), but there is maybe a hint for the looping of all cs968 inside. Could the lan frequency be the cause of the loop?
          Gesendet von meinem Nexus 7 mit Tapatalk
            http://www.freaktab.com/showthread.p...-rk3188-kernel!
            Using my ipad so apols for any stupid ios spelling 'corrections'
            Donate to Finless
              ha !
              I see how to patch kernel to build CPU/GPU/DDR several combinations and I did it, but I do not see what to do for " USB ethernet support and full NTFS support - multiple partitions" ???
              In other hand can you tell me which frequencies you use to build a kernel for me "kernel_16_1080_fast" in your post 488 and whitch table, 6-7-4 or 6-7-3 ? 6-7-4 sound/look good for now.
              thanks for that
                Originally posted by mikele View Post
                ha !
                In other hand can you tell me wich frequencies you use to build a kernel for me "kernel_16_1080_fast" in your post 488 and witch table, 6-7-4 or 6-7-3 ?
                thanks for that
                The NTFS and USB Ethernet are built in, you just need to patch the kernel frequencies to your own combo.
                Donate to Finless
                  Is Overclockomatic a good way for "T" models ? I mean to override "T" chip limitations ?
                  I do not see any GPU/DDR changes in tables for the kernel you build for me post 488 "kernel_16_1080_fast"
                    AW: Blacklist of locked Down Version´s of RK3188 CPU
                    No wonder they all came from the same manufacturer
                    Only a different Brand.
                    Neomode
                      I tested the script and found a 'bug' (not really - more a required change). The DDR definitions have changed in KK beta. I've posted the changes required in KK kernels to PHJAnderson's thread. I'll post the full amended script below.
                      If this is not the done thing I'll delete the script.
                      Donate to Finless
                        Untested - but does now identify and patch kk beta kernels
                        #!/usr/bin/perl
                        # Copyright 2013 phjanderson
                        #amended by Darrell Reed to patch android 4.4.2 kernels
                        # This program is free software: you can redistribute it and/or modify
                        # it under the terms of the GNU General Public License as published by
                        # the Free Software Foundation, either version 3 of the License, or
                        # (at your option) any later version.
                        # This program is distributed in the hope that it will be useful,
                        # but WITHOUT ANY WARRANTY; without even the implied warranty of
                        # MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
                        # GNU General Public License for more details.
                        # You should have received a copy of the GNU General Public License
                        # along with this program. If not, see <http://www.gnu.org/licenses/>.
                        use strict;
                        # GPU frequency cap search list
                        my @gpu_cap_search_list = (
                        [133000000, 266000000],
                        [133000000, 400000000],
                        [133000000, 466000000],
                        [133000000, 500000000],
                        [133000000, 533000000],
                        [133000000, 600000000],
                        # GPU frequency cap replacement
                        my @gpu_cap_replace = (133000000, 800000000);
                        # these voltages are used to search for voltage/frequency tables
                        my @volt_list = (800000, 825000, 850000, 875000, 900000, 925000, 950000, 975000, 1000000, 1025000, 1050000, 1075000, 1100000, 1125000, 1150000, 1175000, 1200000, 1225000, 1250000, 1275000, 1300000, 1325000, 1350000, 1375000, 1400000, 1425000, 1450000);
                        # for the frequencies we just generate a list of all frequencies between 100 and 2500mhz - amended by DR to get new kitkat DDR definitions
                        my @freq_list;
                        for ( my $mhz = 100 ; $mhz <= 2500 ; $mhz++ ) {
                        push( @freq_list, $mhz * 1000 );
                        push( @freq_list, $mhz * 1000 + 1 );
                        push( @freq_list, $mhz * 1000 + 2 );
                        push( @freq_list, $mhz * 1000 + 4 );
                        push( @freq_list, $mhz * 1000 + 8 );
                        push( @freq_list, $mhz * 1000 + 16 );
                        push( @freq_list, $mhz * 1000 + 256 );
                        # below are the profiles used for the patched kernels
                        # please remember that they cannot be longer than the frequency tables inside the kernel you are patching
                        # CPU profiles
                        my %cpu_profiles = (
                        "cpustock" => 0,
                        "cpu1608h" =>
                        [1150000, 1200000],
                        [1250000, 1416000],
                        [1350000, 1608000],
                        "cpu1704h" =>
                        [1150000, 1200000],
                        [1350000, 1608000],
                        [1375000, 1704000],
                        "cpu1800h" =>
                        [1150000, 1200000],
                        [1350000, 1608000],
                        [1375000, 1800000],
                        "cpu1920h" =>
                        [1150000, 1200000],
                        [1350000, 1608000],
                        [1450000, 1920000],
                        # GPU profiles
                        my %gpu_profiles = (
                        "gpustock" => 0,
                        # "gpu600" =>
                        # [975000, 133000],
                        # [1000000, 200000],
                        # [1025000, 266000],
                        # [1050000, 300000],
                        # [1100000, 400000],
                        # [1250000, 600000],
                        # "gpu600h" =>
                        "gpu798h" =>
                        [1100000, 400000],
                        [1250000, 600000],
                        [1375000, 798000],
                        # DDR profiles
                        # the final digit of the frequency signifies the following:
                        # 1 DDR_FREQ_SUSPEND
                        # 2 DDR_FREQ_VIDEO
                        # 4 DDR_FREQ_VIDEO_LOW
                        # 8 DDR_FREQ_DUALVIEW
                        # 16 DDR_FREQ_IDLE
                        # 256 DDR_FREQ_NORMAL
                        # only 1, 2 and 256 seem to be used in the source code for KitKat Android sticks and even though 2 is set it doesn't seem to be used
                        my %ddr_profiles = (
                        "ddrstock" => 0,
                        "ddr528" =>
                        [950000, 200001],
                        [1000000, 300002],
                        [1200000, 528256],
                        "ddr667" =>
                        [950000, 200001],
                        [1000000, 300002],
                        [1225000, 667256],
                        "ddr720" =>
                        [950000, 200001],
                        [1000000, 300002],
                        [1250000, 720256],
                        "ddr800" =>
                        [950000, 200001],
                        [1000000, 300002],
                        [1250000, 800256],
                        ########## System variables ##########
                        my %ddr_freq_type_map = (
                        0 => "",
                        1 => "1 DDR_FREQ_SUSPEND",
                        2 => "2 DDR_FREQ_VIDEO",
                        4 => "4 DDR_FREQ_VIDEO_LOW",
                        8 => "8 DDR_FREQ_VIDEO_LOW",
                        16 => "16 DDR_FREQ_IDLE",
                        256 => "256 DDR_FREQ_NORMAL"
                        my $freq_table_end = pack("V", 0) . pack("V", 0xfffffffe);
                        my @crc_table = (
                        0x00000000, 0x04c10db7, 0x09821b6e, 0x0d4316d9,
                        0x130436dc, 0x17c53b6b, 0x1a862db2, 0x1e472005,
                        0x26086db8, 0x22c9600f, 0x2f8a76d6, 0x2b4b7b61,
                        0x350c5b64, 0x31cd56d3, 0x3c8e400a, 0x384f4dbd,
                        0x4c10db70, 0x48d1d6c7, 0x4592c01e, 0x4153cda9,
                        0x5f14edac, 0x5bd5e01b, 0x5696f6c2, 0x5257fb75,
                        0x6a18b6c8, 0x6ed9bb7f, 0x639aada6, 0x675ba011,
                        0x791c8014, 0x7ddd8da3, 0x709e9b7a, 0x745f96cd,
                        0x9821b6e0, 0x9ce0bb57, 0x91a3ad8e, 0x9562a039,
                        0x8b25803c, 0x8fe48d8b, 0x82a79b52, 0x866696e5,
                        0xbe29db58, 0xbae8d6ef, 0xb7abc036, 0xb36acd81,
                        0xad2ded84, 0xa9ece033, 0xa4aff6ea, 0xa06efb5d,
                        0xd4316d90, 0xd0f06027, 0xddb376fe, 0xd9727b49,
                        0xc7355b4c, 0xc3f456fb, 0xceb74022, 0xca764d95,
                        0xf2390028, 0xf6f80d9f, 0xfbbb1b46, 0xff7a16f1,
                        0xe13d36f4, 0xe5fc3b43, 0xe8bf2d9a, 0xec7e202d,
                        0x34826077, 0x30436dc0, 0x3d007b19, 0x39c176ae,
                        0x278656ab, 0x23475b1c, 0x2e044dc5, 0x2ac54072,
                        0x128a0dcf, 0x164b0078, 0x1b0816a1, 0x1fc91b16,
                        0x018e3b13, 0x054f36a4, 0x080c207d, 0x0ccd2dca,
                        0x7892bb07, 0x7c53b6b0, 0x7110a069, 0x75d1adde,
                        0x6b968ddb, 0x6f57806c, 0x621496b5, 0x66d59b02,
                        0x5e9ad6bf, 0x5a5bdb08, 0x5718cdd1, 0x53d9c066,
                        0x4d9ee063, 0x495fedd4, 0x441cfb0d, 0x40ddf6ba,
                        0xaca3d697, 0xa862db20, 0xa521cdf9, 0xa1e0c04e,
                        0xbfa7e04b, 0xbb66edfc, 0xb625fb25, 0xb2e4f692,
                        0x8aabbb2f, 0x8e6ab698, 0x8329a041, 0x87e8adf6,
                        0x99af8df3, 0x9d6e8044, 0x902d969d, 0x94ec9b2a,
                        0xe0b30de7, 0xe4720050, 0xe9311689, 0xedf01b3e,
                        0xf3b73b3b, 0xf776368c, 0xfa352055, 0xfef42de2,
                        0xc6bb605f, 0xc27a6de8, 0xcf397b31, 0xcbf87686,
                        0xd5bf5683, 0xd17e5b34, 0xdc3d4ded, 0xd8fc405a,
                        0x6904c0ee, 0x6dc5cd59, 0x6086db80, 0x6447d637,
                        0x7a00f632, 0x7ec1fb85, 0x7382ed5c, 0x7743e0eb,
                        0x4f0cad56, 0x4bcda0e1, 0x468eb638, 0x424fbb8f,
                        0x5c089b8a, 0x58c9963d, 0x558a80e4, 0x514b8d53,
                        0x25141b9e, 0x21d51629, 0x2c9600f0, 0x28570d47,
                        0x36102d42, 0x32d120f5, 0x3f92362c, 0x3b533b9b,
                        0x031c7626, 0x07dd7b91, 0x0a9e6d48, 0x0e5f60ff,
                        0x101840fa, 0x14d94d4d, 0x199a5b94, 0x1d5b5623,
                        0xf125760e, 0xf5e47bb9, 0xf8a76d60, 0xfc6660d7,
                        0xe22140d2, 0xe6e04d65, 0xeba35bbc, 0xef62560b,
                        0xd72d1bb6, 0xd3ec1601, 0xdeaf00d8, 0xda6e0d6f,
                        0xc4292d6a, 0xc0e820dd, 0xcdab3604, 0xc96a3bb3,
                        0xbd35ad7e, 0xb9f4a0c9, 0xb4b7b610, 0xb076bba7,
                        0xae319ba2, 0xaaf09615, 0xa7b380cc, 0xa3728d7b,
                        0x9b3dc0c6, 0x9ffccd71, 0x92bfdba8, 0x967ed61f,
                        0x8839f61a, 0x8cf8fbad, 0x81bbed74, 0x857ae0c3,
                        0x5d86a099, 0x5947ad2e, 0x5404bbf7, 0x50c5b640,
                        0x4e829645, 0x4a439bf2, 0x47008d2b, 0x43c1809c,
                        0x7b8ecd21, 0x7f4fc096, 0x720cd64f, 0x76cddbf8,
                        0x688afbfd, 0x6c4bf64a, 0x6108e093, 0x65c9ed24,
                        0x11967be9, 0x1557765e, 0x18146087, 0x1cd56d30,
                        0x02924d35, 0x06534082, 0x0b10565b, 0x0fd15bec,
                        0x379e1651, 0x335f1be6, 0x3e1c0d3f, 0x3add0088,
                        0x249a208d, 0x205b2d3a, 0x2d183be3, 0x29d93654,
                        0xc5a71679, 0xc1661bce, 0xcc250d17, 0xc8e400a0,
                        0xd6a320a5, 0xd2622d12, 0xdf213bcb, 0xdbe0367c,
                        0xe3af7bc1, 0xe76e7676, 0xea2d60af, 0xeeec6d18,
                        0xf0ab4d1d, 0xf46a40aa, 0xf9295673, 0xfde85bc4,
                        0x89b7cd09, 0x8d76c0be, 0x8035d667, 0x84f4dbd0,
                        0x9ab3fbd5, 0x9e72f662, 0x9331e0bb, 0x97f0ed0c,
                        0xafbfa0b1, 0xab7ead06, 0xa63dbbdf, 0xa2fcb668,
                        0xbcbb966d, 0xb87a9bda, 0xb5398d03, 0xb1f880b4,
                        ########## Functions ##########
                        sub calculate_rkcrc {
                        my ($data) = @_;
                        my $crc = 0;
                        my $data_size = length($data);
                        my $idx = 0;
                        for ( my $idx = 0 ; $idx < $data_size ; $idx++ ) {
                        $crc = $crc << 8 ^ $crc_table[$crc >> 24 ^ unpack( "C", substr( $data, $idx, 1 ) )];
                        $crc = $crc % 0x100000000;
                        return $crc;
                        sub read_kernel {
                        my ($srcfile) = @_;
                        my $buffer;
                        my $filesize = -s $srcfile;
                        open INF, $srcfile
                        or die "\nCan't open $srcfile for reading: $!\n";
                        binmode INF;
                        read (INF, $buffer, $filesize);
                        close INF
                        or die "Can't close $srcfile: $!\n";
                        return $buffer;
                        sub parse_table_data {
                        my ($table_data) = @_;
                        my @table;
                        my $table_size = length( $table_data ) / 8 - 1;
                        for ( my $idx = 0 ; $idx < $table_size ; $idx++ ) {
                        my $volt = unpack( "V", substr( $table_data, $idx * 8, 4 ) );
                        my $freq = unpack( "V", substr( $table_data, $idx * 8 + 4, 4 ) );
                        my @entry = ( $volt, $freq );
                        push( @table, \@entry );
                        return \@table;
                        sub pack_table_data {
                        my ($table_ref) = @_;
                        my $table_data = "";
                        for my $entry_ref ( @$table_ref ) {
                        my ( $volt, $freq ) = @$entry_ref;
                        $table_data .= pack( "V", $volt );
                        $table_data .= pack( "V", $freq );
                        $table_data .= $freq_table_end;
                        return $table_data;
                        sub find_tables {
                        my ($buffer, $freq_list_ref, $volt_list_ref) = @_;
                        my $regex="((" . join("|", map { my $packed = pack("V", $_); "\Q$packed\E" } @$volt_list_ref) . ")(" . join("|", map { my $packed = pack("V", $_); "\Q$packed\E" } @$freq_list_ref) . "))+" . $freq_table_end;
                        my %tables;
                        while ($buffer =~ /$regex/gs) {
                        $tables{ $-[0] } = parse_table_data( ${^MATCH} );
                        return \%tables;
                        sub display_table {
                        print "MHz\tmV\n";
                        print int($freq/1000);
                        print "\t";
                        print int($volt/1000);
                        if ( $freq%1000 > 0 ) {
                        print "\t" . $ddr_freq_type_map{ $freq%1000 };
                        print "\n";
                        ########## Main ##########
                        print "=============================\n";
                        print "Rockchip Patchomatic Suite\n";
                        print "Overclockomatic RK3188 v1.2\n";
                        print "by phjanderson\n";
                        print "=============================\n\n";
                        if ( @ARGV != 1 ) {
                        print "Error: no kernel image specified\n\n";
                        print "Please specify a kernel image file name\n\n";
                        exit( -1 );
                        my $srcfile = $ARGV[0];
                        my $target_base = $srcfile;
                        $target_base =~ s/\.[^.]+$//;
                        my $target_ext = substr( $srcfile, length( $target_base ) );
                        print "Reading kernel image\n";
                        my $buffer = read_kernel( $srcfile );
                        print "Done!\n\n";
                        print "Searching GPU frequency limit cap\n";
                        my $gpu_cap_found = 0;
                        for my $gpu_cap_search (@gpu_cap_search_list) {
                        my $gpu_cap_search_data = pack("V", $gpu_cap_search->[0]) . pack("V", $gpu_cap_search->[1]);
                        my $gpu_cap_search_count =()= $buffer =~ /\Q$gpu_cap_search_data\E/g;
                        if ( $gpu_cap_search_count == 1 ) {
                        print "Found: " . $gpu_cap_search->[0] . ", " . $gpu_cap_search->[1] . "\n";
                        print "Patching...\n";
                        my $gpu_cap_replace_data = pack("V", $gpu_cap_replace[0]) . pack("V", $gpu_cap_replace[1]);
                        $buffer =~ s/\Q$gpu_cap_search_data\E/$gpu_cap_replace_data/g;
                        $gpu_cap_found = 1;
                        last;
                        if( !$gpu_cap_found ) {
                        print "Warning: unable to patch the GPU frequency limit cap!\n";
                        print "Searching GPU frequency limit cap (reversed)\n";
                        $gpu_cap_found = 0;
                        my $gpu_cap_search_data = pack("V", $gpu_cap_search->[1]) . pack("V", $gpu_cap_search->[0]);
                        my $gpu_cap_replace_data = pack("V", $gpu_cap_replace[1]) . pack("V", $gpu_cap_replace[0]);
                        $gpu_cap_found = 1;
                        last;
                        print "Warning: unable to patch the GPU frequency limit cap (reversed)!\n";
                        print "\n";
                        print "Searching volt/frequency tables\n";
                        my $tables_ref = find_tables( $buffer, \@freq_list, \@volt_list );
                        my %tables = %$tables_ref;
                        print "Done!\n\n";
                        if ( scalar keys %tables < 3 ) {
                        print "Error: found only " . ( scalar keys %tables ) . " frequency tables, at least 3 are needed\n\n";
                        exit( -1 );
                        print "Volt/frequency tables found in the image:\n";
                        my $table_idx = 1;
                        my %table_idx_offset_map;
                        for my $offset ( sort { $a <=> $b } keys %tables ) {
                        my $table_ref = $tables{ $offset };
                        $table_idx_offset_map{ $table_idx } = $offset;
                        print "== Table $table_idx at offset $offset ==\n";
                        display_table( $table_ref );
                        print "\n";
                        $table_idx++;
                        print "== End of tables ==\n\n";
                        print "Please identify the CPU, GPU and DDR table. Press ctrl-c to cancel.\n\n";
                        my $input;
                        my $cpu_table_offset = 0;
                        do {
                        print "Which table is the CPU table?\n";
                        print "(The CPU table is mostly the largest table ranging from 312 to 1608 MHz)\n";
                        chomp ($input = <STDIN>);
                        if ( exists $table_idx_offset_map{ int($input) } ) {
                        $cpu_table_offset = $table_idx_offset_map{ int($input) };
                        else {
                        print "Table does not exist.\n";
                        print "\n";
                        } until ( $cpu_table_offset != 0 );
                        my $cpu_table_ref = $tables{$cpu_table_offset};
                        my $cpu_table_length = @$cpu_table_ref;
                        my $gpu_table_offset = 0;
                        do {
                        print "Which table is the GPU table?\n";
                        print "(The GPU table is mostly the second largest table ranging from 133 to 600 MHz)\n";
                        $gpu_table_offset = $table_idx_offset_map{ int($input) };
                        else {
                        print "\n";
                        } until ( $gpu_table_offset != 0 );
                        my $gpu_table_ref = $tables{$gpu_table_offset};
                        my $gpu_table_length = @$gpu_table_ref;
                        my $ddr_table_offset = 0;
                        do {
                        print "Which table is the DDR table?\n";
                        print "(The DDR table is mostly quite short, mostly 2 entries, and can be recognized by the labels DDR_FREQ_... at the end of each line)\n";
                        $ddr_table_offset = $table_idx_offset_map{ int($input) };
                        else {
                        print "\n";
                        } until ( $ddr_table_offset != 0 );
                        my $ddr_table_ref = $tables{$ddr_table_offset};
                        my $ddr_table_length = @$ddr_table_ref;
                        print "Patching kernels... please wait...\n\n";
                        foreach my $cpu_profile_key (keys %cpu_profiles) {
                        foreach my $gpu_profile_key (keys %gpu_profiles) {
                        foreach my $ddr_profile_key (keys %ddr_profiles) {
                        my $target_buffer = $buffer;
                        my $cpu_profile_table_ref = $cpu_profiles{ $cpu_profile_key };
                        my $cpu_profile_table_length = 0;
                        if ( $cpu_profile_table_ref != 0 ) {
                        $cpu_profile_table_length = @{$cpu_profile_table_ref};
                        my $gpu_profile_table_ref = $gpu_profiles{ $gpu_profile_key };
                        my $gpu_profile_table_length = 0;
                        if ( $gpu_profile_table_ref != 0 ) {
                        $gpu_profile_table_length = @{$gpu_profile_table_ref};
                        my $ddr_profile_table_ref = $ddr_profiles{ $ddr_profile_key };
                        my $ddr_profile_table_length = 0;
                        if ( $ddr_profile_table_ref != 0 ) {
                        $ddr_profile_table_length = @{$ddr_profile_table_ref};
                        if ( $cpu_profile_table_length > $cpu_table_length ) {
                        print "ERROR: CPU profile table $cpu_profile_key is larger than the CPU table in the kernel";
                        exit -1;
                        else {
                        my $new_cpu_table_data = pack_table_data( $cpu_profile_table_ref ) . ($freq_table_end x ($cpu_table_length - $cpu_profile_table_length));
                        my $new_cpu_table_data_length = length( $new_cpu_table_data );
                        $target_buffer = substr( $target_buffer, 0, $cpu_table_offset) . $new_cpu_table_data . substr( $target_buffer, $cpu_table_offset + $new_cpu_table_data_length);
                        else {
                        #print "CPU stock mode, not patching the CPU table\n";
                        if ( $gpu_profile_table_length > $gpu_table_length ) {
                        print "ERROR: GPU profile table $gpu_profile_key is larger than the GPU table in the kernel";
                        exit -1;
                        else {
                        my $new_gpu_table_data = pack_table_data( $gpu_profile_table_ref ) . ($freq_table_end x ($gpu_table_length - $gpu_profile_table_length));
                        my $new_gpu_table_data_length = length( $new_gpu_table_data );
                        $target_buffer = substr( $target_buffer, 0, $gpu_table_offset) . $new_gpu_table_data . substr( $target_buffer, $gpu_table_offset + $new_gpu_table_data_length);
                        else {
                        #print "GPU stock mode, not patching the GPU table\n";
                        if ( $ddr_profile_table_length > $ddr_table_length ) {
                        print "ERROR: DDR profile table $ddr_profile_key is larger than the DDR table in the kernel";
                        exit -1;
                        else {
                        my $new_ddr_table_data = pack_table_data( $ddr_profile_table_ref ) . ($freq_table_end x ($ddr_table_length - $ddr_profile_table_length));
                        my $new_ddr_table_data_length = length( $new_ddr_table_data );
                        $target_buffer = substr( $target_buffer, 0, $ddr_table_offset) . $new_ddr_table_data . substr( $target_buffer, $ddr_table_offset + $new_ddr_table_data_length);
                        else {
                        #print "DDR stock mode, not patching the DDR table\n";
                        my $crc = calculate_rkcrc( substr( $target_buffer, 8, -4 ) );
                        $target_buffer = substr( $target_buffer, 0, -4 ) . pack( "V", $crc );
                        my $target_file = $target_base . "_" . $cpu_profile_key . "_" . $gpu_profile_key . "_" . $ddr_profile_key . $target_ext;
                        print "Writing $target_file\n";
                        open OUTF, ">$target_file"
                        or die "\nCan't open $target_file for writing: $!\n";
                        binmode OUTF;
                        print OUTF $target_buffer;
                        close OUTF
                        or die "Can't close $target_file: $!\n";
                        print "\nAll done!\n";
                        Donate to Finless
                          #!/usr/bin/perl
                          # Copyright 2013 phjanderson amended by darrel
                          Ok I can see now so thats run ok. Thanks. But now I see two tables for DDR in your "FAST" kernel and others ? 8 (8781576) and 9 (8781608) ?
                          by phjanderson
                          == Table 1 at offset 8766752 ==
                          MHz mV
                          816 1000
                          == Table 2 at offset 8770416 ==
                          MHz mV
                          500 1100
                          == Table 3 at offset 8770440 ==
                          MHz mV
                          180 1150
                          300 1100
                          400 1150
                          500 1200
                          == Table 4 at offset 8770480 ==
                          MHz mV
                          200 1000
                          300 1050
                          400 1100
                          500 1150
                          600 1200
                          == Table 5 at offset 8770528 ==
                          MHz mV
                          816 1050
                          == Table 6 at offset 8781480 ==
                          MHz mV
                          1200 1200
                          1416 1250
                          1608 1350
                          1800 1375
                          == Table 7 at offset 8781520 ==
                          MHz mV
                          133 975
                          200 1000
                          266 1025
                          300 1050
                          400 1100
                          600 1250
                          == Table 8 at offset 8781576 ==
                          MHz mV
                          200 950 1 DDR_FREQ_SUSPEND
                          300 1000 2 DDR_FREQ_VIDEO
                          720 1200 256 DDR_FREQ_NORMAL
                          == Table 9 at offset 8781608 ==
                          MHz mV
                          460 1200 256 DDR_FREQ_NORMAL
                          == End of tables ==
                          So When rkpatchomatic ask to identify tables I can say that table 6 is for CPU, GPU for table 7 and DDR for table 9 ? right ?
                            MHz mV
                            MHz mV
                            == End of tables ==
                            I prepared a suite of kernels for patching with T override removed. The example above is one of the auto-switching kernels with override still in place. CPU will stay locked in that kernel but amending the DDR in table 9 will have an affect. Table 8 is the frequency for DDR for a non-T kernel.
                            I strongly suggest you use the kernels I prepare for patching, they are better builds and have CPU/DDR overrides removed.
                            Donate to Finless
                              Re: Blacklist of locked Down Version´s of RK3188 CPU
                              I think is 8 not 9 the ddr table.
                              leolas.
                              My devices:
                              Gearbest.com)
                                leolas.
                                Leolas, they are both DDR tables as explained above.
                                Table 8 is DDR for RK3188
                                Table 9 is DDR for RK3188T
                                But, again, don't use that kernel use the special kernels provided in #614
                                Donate to Finless
