I have managed to boot KitKat on CS968 with a kernel from minix x7 and one from UT1, but cpu is 1.4ghz and i have no wifi!
Blacklist of locked Down Version´s of RK3188 CPU
Originally posted by unaszplodrmann View PostNope.
lower binned units were given the T designation and were etched as such to avoid confusion. Rockchip clearly did not commit fraud. Some consumer device manufacturers and resellers are committing fraud, however. It is especially devious were the device manufacturer or reseller sold devices based on the T variant at the same retail price as units based on the standard RK3188, even though Rockchip sold them the T for less.
Until rockchip releases the actual specification they are in the dark shadow as well, I think that suppliers manufactures where told same chipset just with tablet instructions in code. But until its released and pretty sure it will never be, no one knows who is involved and or what manufactures where told.Many devices now mk902ii/Shield/Mk68 /Ugoos/neox5/minix5 (yes they still work lol) mk80 no it doesnt work lol.
Originally posted by JDfense View PostI asked similar question before.
Could you compile a kernel with only slightly clock increasement for the RAM and GPU. Let the cpu clock on 1.4GHz.
When this kernel will boot complete the cs968, we will have some proof that every T model could run with your T-model kitkat sources, even the weakest t-cpu.
JDfense ----> Nexus 7 ▶ 2013
The kernel below is a test for another person but should do for you too. After you post the standard DMESG try this and post DMESG from this too.
NB. I haven't worked out how to override GPU yet. Too few people have provided output and I don't have a 'T' device nor unlimited time.Measy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Originally posted by d33 View PostJDefense has ANY KitKat kernel booted completely on your device? If so post the DMESG.
None of your kitkat kernels booted complete, but I'll check it again.
If anything will boot complet, I'll send the dmesg.
Thx, d33.
JDfense
The lower binned units were given the T designation and were etched as such to avoid confusion. Rockchip clearly did not commit fraud. Some consumer device manufacturers and resellers are committing fraud, however. It is especially devious were the device manufacturer or reseller sold devices based on the T variant at the same retail price as units based on the standard RK3188, even though Rockchip sold them the T for less.
Okay, I'm kidding.
And I replace the word fraud with two words: clever business. Sounds more friendly.
But let me know, when you found the Model T with specifications on the homepage of Rockship.
JDfense
<6>[ 0.531144] lcdc0 is used as external display device contoller!
<6>[ 0.537768] lcdc1 is used as primary display device controller!
... and is a jelly bean kernel? It certainly isn't built with the KK sources leaked
I can see it has been built with "T" frequencies:- ddrfreq: normal 456MHz video 0MHz dualview 0MHz idle 0MHz suspend 0MHz reboot 222MHz
- mali freq table :Mali: 128,Mali: 179,Mali: 223,Mali: 297,Mali: 297,Mali: 446,Mali:
So 1.4/446/460 same as the limits in the leaked KK beta sources.Measy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Originally posted by d33 View PostAny future people that test all I think we need to know is the fastest stable kernel and the leakage level from DMESG
Digger: 1.6 GHz with leakage level 6000
valzja: 1.6 GHz with leakage level 6000
mikele: 1.6 GHz with leakage level 4000
Norbert6: 1.7 GHz with leakage level 4000Measy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Or you mean something else with the two display controller. The cs968 has a hdmi and AV out.
JDfense
Originally posted by JDfense View PostYes, of course it is one of the stock ROMs 4.22 for ap6210 cs968 with 720p and upscaled (I think) 1080p.
JDfense
Have you ever installed a KitKat ROM and had it boot?Measy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
If and when you find a Kitkat kernel that boots then post the DMESG and I can build an override for you
Sent from my iPhone using TapatalkMeasy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Originally posted by dracosc22679 View PostShall i also post DMESG of my CS968 booting KitKat using UT1 and minix X7 kernels (wifi no working) ?
For clarity.
1. You can boot your CS968 into Kitkat with custom kernels from Wasser or stock kernels from Minix?
2. You can/can't boot your CS968 into KitKat using my kernels?Measy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Originally posted by dracosc22679 View PostCan boot KK using kernel-ut1.img from wasser KK rom, and using 2-3 custom minix x7 roms!
Cannot boot KK with ANY other kernel!
P.S: Your last 6210 no override kernel, gives me distortion on boot animation and then reboor. NO BOOT again :-(Measy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
There are currently 6549 users online. 1 members and 6548 guests.
