Blacklist of locked Down VersionĀ“s of RK3188 CPU
    Ray, I think I have tested your ROM, but I have to check at home later. Maybe I miss the one and only. :-)
    JDfense --->I8160
      @ JDfense
      Did u tried it with bootloader 2.13? I think they work at both JB and KK. I use it on KK atm.
      I can flash this bootloader to test on my 1st JB tv-stick. Better to brick mine than urs.
      cx-919ii
        No, I did never tried a bootloader 2.13.
        Hm. Good idea, better yours, because no one should be forced to buy a second Model T.;-)
        JDfense --->I8160
          Ok. Im gonna try it now. And yeah T chips are maybe bad but not that bad
          Ich mach mal das Versuchskaninchen
          cx-919ii
            RK3188Loader-L-_V2.13.bin works with JB and KK.
            Leider konnte Ihre hochgeladene Datei nicht gefunden werden. Laden Sie die Datei neu hoch.
            All the devs should use this multiLoader in future = less bricked devices
            If u wanna know where i got it from?
            From this site http://www.rikomagic.com/en/download/download_28_1.html
            Exctracted it from this Firmware RKM MK902 Software(140308)
            Its a 4.2.2 JB Firmware
            cx-919ii
              OK. Das war mutig. :-)
              Good to know. I will try it later.
              JDfense --->I8160
                Originally posted by d33 View Post
                Ok. I need a few guinea pigs to help me.
                I've downloaded the Jelly bean sources, added RK3188T detection and compiled. However, I can't test
                So, can a few of you test this kernel for me?
                You will need a Jelly Bean ROM installed.
                1. Flash my kernel
                2. Tell me if it boots
                3. If succesful so far, post me your DMESG
                I test this on my ΜΚ908ii with Finless 1.5a but not boot
                  Originally posted by neomode View Post
                  Have you try it with my MK809III 2.1 Rom ?
                  This have a 1.xx Loader that Works with T Cpu also.
                  Ray
                  Okay, I've tested your ROM. The included boatloader 1.24 is like poison for my cs968 - hard bricked my device, but I'm lucky back, finally it jumps back to loader mode, after I tried all tricks I know.
                  So all cs968 user, stay away from the 1.24 bootloader.
                  After that I flashed your ROM successfully with the 2.13 booloader, thx max one, this 2.13 bootloader seems to be the universal flashing soldier. As a result the flashing was complete without error, but the ROM does not boot, it seems like I have no power supply, no kernel logo or any flickering for trying to start. This ROM can't start my device. Then I changed the kernel to stock, but no choice. It does not boot.
                  Thanks Ray, but the cs968 seems be a very special device.
                  JDfense
                  PS.: Time for the d33 JB kernel.
                    1. Flash my kernel
                    I've tested your kernel with MBox(another cs968 clone) 720p stock rom, but no choice. It boots for a second, then it bootloops and boots again.
                    JDfense
                      1. Flash my kernel
                      No joy with either loader 1.20 or 1.24 on my mk908ii as well. If I flash the Finless 1.5a boot, misc, recovery, and system with your kernel I see "formatting" messages at startup, but then the screen starts blinking and finally alternates between between black & no signal.
                      Loader 2.13 boots into recovery but I can't get past recovery and the screen is blinking.
                        Thanks for testing - I'll work on it. I've removed the download
                        Donate to Finless
                          Any progress on JB's kernels development d33?
                            Nah, Gave up. Just got an AMLogic quad core Tablet to play with and still working to get a KK kernel for Cube U30GT2
                            Donate to Finless
                              Any new for final KK ? I saw somewhere this is done...
                                Here is a Little Program to check if the CPU is a T Model or not.
                                Please Test it.
                                Thx.
                                Neomode
                                Removed app not Work as Should, make a new one.
                                Has a new one been made.
                                I tried this one and it said I seemed to have a real RK3188, however, the chip itself has RK3188-T on it.
                                EDIT: scrap that
                                NEOMode's app doesn't work. I have his source code and I'll fix it but:
                                1. I have a ridiculously long list of things people would like already
                                2. Bob needs my support which comes first
                                3. The hotel I'm staying in this week blocks the HDMI ports so I can't work on my hobby in the evenings
                                Sorry all
