Blacklist of locked Down Version´s of RK3188 CPU
Originally posted by neomode View PostI have something find out about GPU Overclocking.
Right now I am making a Rom for the MK902. I have overlooked the Kernel with the Tool from pjhanderson. I have got a 1,6 GHz Kernel with GPU Set to 600 MHz.
Then I Flash the Rom and see I only get 466 at max for the GPU, then I found out how to fix it.
In the Boot.img is the init.rc there is a Line for the Mali Freq.
There you can set the Overclock!
insmod /system/lib/modules/mali.ko mali_dvfs=150,200,233,260,300,466,600
The Freq must be the same as in the Kernel.
This Works !
Before i get a Antutu 3D of 2000 now 2600.
NeomodeMeasy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Originally posted by valzja View Postpjhanderson pachomatic not working on all T devices... d33 managed to overclock KitKat ROM to 1.6 ghz, but it seems that GPU and RAM stays where it is. Maybe d33 CPU overclocking and Your GPU overclocking will be way to go...
I need further input to work out the GPUMeasy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Originally posted by digger View Post
I would be glad to join tester's crew here but cannot. You kernels have another USB Hub driver and leave my K-r42 without mouse and any usb connection.Measy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Donate to Finless
Originally posted by mikele View Postis it 1080p ?
Sent from my iPhone using TapatalkMeasy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Originally posted by mikele View Postd33 I understand this kernels is for model T and KiTkAt ? right ? 1.7 . 1.8 overide
Donate to Finless
Originally posted by valzja View PostThose are new builds ? I will test them latter and write my results...
Sent from my Nexus 5 using TapatalkMeasy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Originally posted by d33 View PostDo you know the chipset of the USB hub in your device?
It is FE 1.1 USB 2.0 High Speed 4-Port Hub Controller by TERMINUS
Here is a brief:
CS918II/16GB(HTC-031-V1.0 board)
CS918 (TN-BX09_V2.1 2013/05/31) FW: k-r42-old_revision-wasser-1.2.3- fried by 12V PS
K-R42 board version B351_V2.0 1348, wifi Realtek8188ETV , RK3188T;FW: wasser-firmware-kr42-new-1.0.3
d33,
Please do not do anything with my USB issue.
I have just tried to connect my mose through the OTG>USB adapter and this works.
I will make all the test and send my report.
ThanksCS918II/16GB(HTC-031-V1.0 board)
so, here are my results with mk908II, rk3188t
(I just only flash over the new kernels, not sure if this falsify the results?)
1.5 override RAM
AnTuTu score: 16447
AnTuTu CPU freg: 1200~1512
Code:<6>[ 0.731899] CPU is ROCKCHIP RK3188T <4>[ 0.730993] DVFS MSG: aclk_gpu: dvfs_adjust_table_lmtvolt get leakage_level = 4000 <4>[ 4.931618] Mali: mali freq table :Mali: 128,Mali: 179,Mali: 223,Mali: 297,Mali: 297,Mali: 446,Mali: <6>[ 2.158026] ddrfreq: normal 528MHz video 300MHz video_low 0MHz dualview 0MHz idle 0MHz suspend 198MHz reboot 222MHz
1.6 LV override RAM
Android crashes
AnTuTu CPU freq: 1200~1608
Code:<6>[ 0.735838] CPU is ROCKCHIP RK3188T <4>[ 0.734928] DVFS MSG: aclk_gpu: dvfs_adjust_table_lmtvolt get leakage_level = 4000 <4>[ 5.680303] Mali: mali freq table :Mali: 128,Mali: 179,Mali: 223,Mali: 297,Mali: 297,Mali: 446,Mali: <6>[ 2.121749] ddrfreq: normal 528MHz video 300MHz video_low 0MHz dualview 0MHz idle 0MHz suspend 198MHz reboot 222MHz
AnTuTu score: 17690
AnTuTu CPU freq: 1200~1704
Code:<6>[ 0.735965] CPU is ROCKCHIP RK3188T <4>[ 0.735052] DVFS MSG: aclk_gpu: dvfs_adjust_table_lmtvolt get leakage_level = 4000 <4>[ 4.955662] Mali: mali freq table :Mali: 128,Mali: 179,Mali: 223,Mali: 297,Mali: 297,Mali: 446,Mali: <6>[ 2.121864] ddrfreq: normal 528MHz video 300MHz video_low 0MHz dualview 0MHz idle 0MHz suspend 198MHz reboot 222MHz
AnTuTu crashes
AnTuTu CPU freq: 1200~1800
Code:<6>[ 0.736485] CPU is ROCKCHIP RK3188T <4>[ 0.735569] DVFS MSG: aclk_gpu: dvfs_adjust_table_lmtvolt get leakage_level = 4000 <4>[ 5.767508] Mali: mali freq table :Mali: 128,Mali: 179,Mali: 223,Mali: 297,Mali: 297,Mali: 446,Mali: <6>[ 2.122453] ddrfreq: normal 720MHz video 300MHz video_low 0MHz dualview 0MHz idle 0MHz suspend 198MHz reboot 222MHz
AnTuTu crashes
Code:<6>[ 0.736448] CPU is ROCKCHIP RK3188T <4>[ 0.735539] DVFS MSG: aclk_gpu: dvfs_adjust_table_lmtvolt get leakage_level = 4000 <4>[ 5.567729] Mali: mali freq table :Mali: 128,Mali: 179,Mali: 223,Mali: 297,Mali: 297,Mali: 446,Mali: <6>[ 2.162710] ddrfreq: normal 528MHz video 300MHz video_low 0MHz dualview 0MHz idle 0MHz suspend 198MHz reboot 222MHz
There are currently 3054 users online. 1 members and 3053 guests.
