I'm kinda busy until later tonight, but I will try the USB hub configuration and report.
Pipo U8 RileyROM 1.9 KitKat
The U8 is the only one that charges by USB. The M7 Pro has an external charger.
I'm kinda busy until later tonight, but I will try the USB hub configuration and report.Randy
Under settings/apps...go to Google Play Services and clear the cache/data. You will need to enter your account information again. That should fix the problem.Randy
Sounds like you need to flash again. Be sure to erase IDB to clear everything and start from scratch. I hope you have a Titanium backup.Randy
Sorry, I haven't. I had a few ROMs that I needed to publish.
I will try it tomorrow.Randy
I have been reading the Unofficial TWRP 2.7.0.0 for Rockchip's and it is not clear to me whether there is a working TWRP with your KK roms 1.8 & 1.9
I 've seen your posts "I'm testing the M7 Pro and U8 versions right now...quite an improvement over the alpha...but still a little rough. We still have some screen refresh issues on the menu, and the file manager doesn't show any folders. Once we get this fixed, we can move to the M6 Pro next, if that's OK with Abdul_Pt.", and I've also seen different links and mentions of "generic update of 1024x600 RK3188".
So, is there a working (even if it is a little rough) TWRP that you can use to take nandroid of your 1.8 & 1.9 KK and then successfully restore it?
If it is not much trouble, could you post a link of the best working TWRP version for our U8 and some basic instructions how to add it to an existing rom (i.e. no new flashing)? Perhaps add it on the 1st post for everyone to find?
Thanks mate!_____________________
PiPO U8 powered by RileyROM 1.8 KitKat
Abdul is still working on the screen issues. I tested another version the other day. As soon as we get a reliable version, I will post further instructions and a link.Randy
Originally posted by madalx View Postno need for reflashing the rom? that's great.
UPDATE: it seems that it is more complicated than i thoughtbecause i tried to edit the file and i got an error that it can not been saved (obviously because it is used from the system)...
Originally posted by manao View PostHi Randy, we use this trick since december for the Pipo M9Pro. Are you speaking about that process ?
I have looked into your nvram_AP6476.txt and it seems the same (our dev has modified the triso2g and swctrlmap_2g. What is the best? This is for M9pro...). Did you modify other lines ?
pa0maxpwr=100
triso2g=8
#triso2g=0
swctrlmap_2g=0x04040404,0x02020202,0x04040404,0x01 0101,0x1ff
#swctrlmap_2g=0x04040404,0x02020202,0x02020202,0x0 10101,0x1ff
Forum de tablette chinoise. posez vos questions sur les tablettes, phablettes et smartphones low cost, chinois.
http://tablette-chinoise.net/pipo-m9...30.html#p47397
Has anyone tried external usb-wifi-dongles?
Or the soldering solution for the M9 Pro? U8 and M9 pro Wifi-antennas look pretty much the same.. http://www.freaktab.com/showthread.p...n-instructions
So, only tethering for me now..._____________________
How can I enable multiple users on this ROM? The usual method doesn't work because the system folder won't remount:
su
mount -o rw,remount /system
echo fw.max_users=8 >> build.prop
Actually, in KitKat the multi user feature is turned off...deep in the system...and I haven't figured out how to edit that part. I've seen some posts on how it's done, but the file names and settings don't match what's in these Pipo ROM's.
The good news is that there is an Xposed Framework Module that will activate multi user and it works quite well. Just install the Xposed Framework and browse their repository for the multi-user module.Randy
There are currently 2197 users online. 0 members and 2197 guests.
