Yeah, you may use paper clip, needle is not a good choise though.
Once tablet is off,
First connect, just connect only. And USB 2 only.
Second run program, just run only, do nothing else
Third depress Esc and then Power, hold them depressed until tablet detected by software. That's why RKBatchTool is mote easy. You'll see green square...
Once you see it flash stock firmware. It's more easy as well as you should not bother about loader version.
Once working on stock, you may flash Riley ROM as explained in guide
