Sent from my SAMSUNG-SGH-I537 using Tapatalk
Pipo M7 Pro RileyROM 2.5 KitKat
I forgot the graphic I used to brand the kernel said 4.2.2...my bad. The ROM is 4.4.2.
Sent from my SAMSUNG-SGH-I537 using TapatalkRandy
Re: Pipo M7 Pro RileyROM 2.5 KitKat
Originally posted by Gamexland View Postmy device version is 2.5 nowshall I upgrading to 2.5.1 ? because it's eating battery high 😥how can I turn off mobile antenna? its on when I'm using wifi
Sent from my m6pro running Riley ROM 1.7 KitKat
Hi randy! First at all I want to thank you for the great job with this rom. It is fast and smooth and it solved (or it seems to) my wifi disconnection problems, previously fixed with Wifi fixer.
I switched to ART mode and the tab is super fast. The only thing that i noticed is that when i reboot the tab it takes a long time (around 3 minutes) to update the apps. The first time i did it I was expecting it, the next not...
Is there something in settings i need to configure to make the boot faster?
Anyway, great rom, even if GPS is not working (but i don't use it on the tab)!
Dennta, you know that with chinese devices it's a bit lottery. Everything depends on assembly quality and people who were working at factory that day your tablet came out. I'm using 1704CPU-720RAM kernel and happy with stability and performance. But this does not mean anything. It may not even boot on 'unlucky' tablet. You should try yourself only to get the answer.
cheeks80, not sure but all my android devices turn the screen on for some time when connected to the mains/charger and even just USB. It was like that on different phones/tablets with different ANdroid versions and different SoC
Originally posted by cheeks80 View PostAfter the ROM install I am seeing that the device boots up automatically when I plug the power cord. Meaning the device has to on during carving... Does not make sense... Apart from this I am loving it...
Sent from my Nexus 5 using Tapatalk
Originally posted by cheeks80 View PostYes I know the screen turns on in a normal scenario and shows the battery indicator. But in this case it boots to OS
Originally posted by cheeks80 View PostWeird but I did not have this issue with jelly Bean based Riley ROMs...
Sv: Pipo M7 Pro RileyROM 2.5 KitKat
Originally posted by fazerg View PostDennta, you know that with chinese devices it's a bit lottery. Everything depends on assembly quality and people who were working at factory that day your tablet came out. I'm using 1704CPU-720RAM kernel and happy with stability and performance. But this does not mean anything. It may not even boot on 'unlucky' tablet. You should try yourself only to get the answer.
I saw that somebody had problems installing their titanium backup when changing to kitkat. Is that working properly for everybody else?
Skickat från min M7pro via Tapatalk 2
There are currently 2129 users online. 1 members and 2128 guests.
