General AML S802 Device release discussions
    S802-H Tronsmart
    Same imagens of Vega
    • Tronsmart New Model TV BOX Vega S89-H
    • CPU: Amlogic S802-H Quad-Core 2.0G (Cortex-A9)
    • GPU: 8 cores Mali450
    • Support Dual band wifi 2.4G & 5G
    • Bluetooth 4.0 version
    • Support Dolby and DTS
    • Android 4.4 OS and support OTA(over the air)
    • 2G DDR3 + 16G Nand flash
    System Config. CPU Amlogic S802-H Quad-Core 2.0G (Cortex-A9)
    GPU Mali-450
    4K*2K Support
    RAM DDR3 2G
    ROM Nand flash 16G
    Expand Memory 1*Micro SD Card Slot, support max 64G
    Antenna Built-in wifi antenna
    Media Video format Support multiple video decoding
    4K*2K H.264 ,1080P
    Picture format JPEG/ BMP/ GIF/ PNG/TIF
    Communication Ethernet 10/100M LAN
    WIFI AP6330,Support 802.11 a/b/g/n,2.4G/5G WIFI
    Bluetooth Bluetooth v4.0
    Sensor/Motor IR Sensor 1*IR
    Indicator Power LED 1* LED
    Button & Ports Button 1*Power Button(physical button), control power on and off,
    1*Update Button(via one pin hole)
    USB2.0 2* Standard USB
    1*Micro USB with OTG
    DC-in 1*DC in Jack
    HDMI 1* standard A HDMI 1.4b out, 4K*2K
    SPDIF 1*S/SPDIF out
    RJ45 1*RJ45
    TF Card Slot 1*TF card slot
    AV 1*AV port
    Power management Adapter 5V 3A
    Software Config. OS Google Android 4.4, support OTA function,
    Language Multi-Language
    Keyboard Qwerty keyboard
    Features Miracast/DLNA Support
    UI Android Original UI
    Dolby Support
    DTS Support
      Very nice!
      I have been waiting for device that support DOLBY TrueHD and DTS HD Bypass through HDMI!
      I really would like a square box but as Finless has this one (without passthrough) his roms should be working on this one.
      Hardware
      H.265 HEVC is not supported but I think I can live without that.
      Should I get the Tronsmart
      Vega S89-H or wait for the Minix Neo X8S or possible Rockchip RK3288?
      Anyone know if passtrough will be supported with Rockchip RK3288?
      Maby I should wait for Amlogic S812 (H?) device as that support hardware H.265 HEVC?
        Re: General AML S802 Device release discussions
        Originally posted by no_spam_for_me View Post
        1.) YES
        2.)
        Do you read at XDA about the rooting the FireTV and the updates in future?
        If I read it, I think it isn't a device for me...
        Do you read about the video stuttering problems with Chromecast?
        If I read it, I know it isn't a device for me...
        The benefit of Roku at the moment is, they don't use rk3188T (but I think also the Minix (mini) X7)... (BTW: genny @minixforums.com (the dev of 'DroidMode') published a 4.4.2 KitKat port from the 'PocketKey' of Cloudproject.it to the Minix X7 some days ago ("The secret of this rom is to be as close as possible to Android AOSP"))
        Google TV...
        We will see...
        They released a new kitkat port some days ago? Have a link for that?
        Signature? Signature!
          Originally posted by ssspacman View Post
          Very nice!
          Hardware
          In my opinion, you have to wait a rk3288. S802h get out 20/05/2014.... In same time than rk3288....
          Or buy a aml s802 now and you ve passthrough with xbmc now :-)
            Will RK3288 have hardware support Dolby and DTS passthrough?
              Miracle ROM for X7 by Cloudproject
              RK3288 Devices
              - Overview BOX (LINK !)
                Hi Guys
                There was a kind of advice to sort out that dependencies not met ,network error kind of errors for Gotham but couldn't find it this time... ( it was like installing old version and back on gotham etc. etc. but not exactly sure what was it )
                Is there anything we can do to make those add ons work like xbmc 12 or 12.2 ? or any way to make 12 or 12.2 to work on s802 devices?
                Cheers
                  I'm not really sure what you mean, but if you want to use add ons from 12.x at 13.x try this:
                  1. Install Frodo (12.3) (Frodo will not have hardware video decoding for AML (it has special builds but is not official))
                  2. Install Add-Ons
                  3a. Download and Install Gotham (13.x latest gotham nightly) (it will ask if you want to install and say it needs no new permissions. Then just click on install. It keeps everything from frodo) OR
                  3b. Download XBMC Updater from the play store. Click nightlies. Click download. Click install. Click install on the android permissions screen. Upgrade complete.
                  => The upgrade keeps your addons
                  (But if every add on will work, that's another question)
                  RK3288 Devices
                    Just changed the runtime from Dalvik to ART seems to work fine so far :-)
                    Sent from my Nexus 5 using Tapatalk
                      Art is perfect for me
                      Donate to Finless
                        Yep, smooths things up and works well :-)
                          The first sample of 3288 is suffering from serious HDMI bug, which is normal, and undergoing the 2nd sample stage. Sell? No way. Don't even think about it. New design instruction will be released by RK next week, all 1st design will be wasted, including ours, again, this is normal.
                            Very nice!
                            Hardware
                            Guess what? Maybe RK3066 will be the first chip supporting all these audio formats. I'm not kidding, RK3066. No way those could happen on S802 because of the lack of I2S channels.
                              Don't think it's possible, they're not even a member of these groups.
                                Originally posted by MINIX View Post
                                ... No way those could happen on S802 because of the lack of I2S channels.
                                I'm a little bit confused.
                                DTS-HD seems to work but Dolby True-HD not
                                RK3288 Devices
