Should give me enough time to download your other rom.
NextBook 7P S (Resisitve screen) - Ice Cream Sandwich - Finless ROM 1.2 Root and Gplay
Update: Bob, it seems to work.
Let me know if I should test any particular functions on it.
Edit: Calibration not correct. Mirror effect as described in past posts. Volume Up/Down, and Power buttons working properly with it though.
Soft keys on bottom only responsive if you touch the top part of the screen. (Mirror Effect)
Another Edit: A lot of the functions having to with mounting, are throwing up errors.
Worked
what works
- vol +, vol - work to move up and down.
- Power button to select.
Not working
- touch controls is off.
- options are not all working right.
"Agree with Plasmastar, same here"
Ah crap
Well so much for a simple way.... Looks like I have to cook up a custom one for this model. It's going to be a while though sorry. As you probably can see I am very tied up on other ROMs... It's a first come first serve request basis.
I sure could use another Dev on the team to handle the nextbook stuff. As you can see I have been kind of neglecting you nextbook folks. Not because I want to... but because of time.
What is Step 1?
Ok, so i have the Nextbook Next7S Android 4.0 ICS, from biglots, and I am just trying to figure out how i go about doing a ROM switch??? What should the next step be? Download rockchip drivers? or download the ROM provided by finless at the beginning of this thread? Sorry for the newb questions, i'm just eager to make my tablet better before I just decide to say screw it and return it
See the README in my ROM download. All tools, instrutions, and drivers are in my ROM kit.
Originally posted by Finless View PostSee the README in my ROM download. All tools, instrutions, and drivers are in my ROM kit.
TY for the quick reply Finless, so I would just download the file, that is in your first post of this thread, to my computer and when i open that up I just go through the readme file and follow step by step? Also, i believe I read on another post that the Nextbook 7P ROM is also good for my tablet even tho it is the 7S, is that correct?
Originally posted by Clueless View PostTY for the quick reply Finless, so I would just download the file, that is in your first post of this thread, to my computer and when i open that up I just go through the readme file and follow step by step? Also, i believe I read on another post that the Nextbook 7P ROM is also good for my tablet even tho it is the 7S, is that correct?
I cannot help on the models. I do not know. If you read a bunch here you will see some people that say they have this or that model, the ROMs do not work for them. Others it does. Nextbook model numbers and what they really is a mess. So your on your own with this for the most part. I cannot help you there.
Netflix update fix
Hey Finless,
After talking to NextBook tech support for over an hour I was formally told that the download here http://www.nextbookusa.com/download.phpnamed NEXT7P-12 Netflix Update under firmware downloads is also made for the Next7S Resistive screen. However after spending over an hour with a technician trying to get the update to work it just wouldn't budge. Apparently to install this update all I need to do is download the update.img, transfer it over to internal storage root directory and when I disconnect the USB cable it should kick in and install the update. However this does not happen at all. The only excuse they gave me why it wouldn't work is because Windows 7 apparently downloads the file incorrectly changing the file type to a CDImage or a WinImage thus crippling the file making it unrecognizable to the tablet(I call BS on this). And they said using XP would fix this problem. I of course questioned their logic behind this but unfortunately did not at the time have an XP machine operational. I did however download the update.img file via the tablets browser and it STILL did nothing which makes me think something else is going on and going the XP route would do nothing. It could be that I have flashed your Finless ROM however I tried it both with the Finless ROM and flashed the stock ROM you have on here (which flashed beautifully might I add) and still wouldn't work.
So my question is this. Can you add the NEXT7P-12 Netflix Update to the stock ROM, upload it for experimental purposes to see if it will work? You could call it "Next7S Resistive Screen Netflix Update EXPERIMENTAL." I'll then flash it and see if it works. If it does then you can add it to your Finless ROM and then we can all enjoy NETFLIX! But I am getting ahead of myself. What say you mighty Finless?
Hello everyone, I'm new here as well as any real modding, so please treat me like a noob when it comes to explaining so I can make sure not to mess anything up. I got a Nextbook 7" Android Tablet with ICS with serial # starting with YF0312 and I would really like to get off the default GetJar and use the Google Play app that won't install, do I want the download from the begining of this thread or if not could I be directed to the right spot? Thanks for any help and advice guys.
Originally posted by anotherguy View PostHello everyone, I'm new here as well as any real modding, so please treat me like a noob when it comes to explaining so I can make sure not to mess anything up. I got a Nextbook 7" Android Tablet with ICS with serial # starting with YF0312 and I would really like to get off the default GetJar and use the Google Play app that won't install, do I want the download from the begining of this thread or if not could I be directed to the right spot? Thanks for any help and advice guys.
I downloaded the Rom a few days ago but just installed it today (had a really bad headcold, & something told me maybe now a good time to try to do this). Just wanted to give my thanks as so many here already has to Finless and everyone else involved with this, just to be able to use Gplay now deserves .
Thanks again and needless to say this site will be one of the first stops for anything else I may need to know/learn in the future
There are currently 3280 users online. 3 members and 3277 guests.
