bob
NextBook 7P S (Resisitve screen) - Ice Cream Sandwich - Finless ROM 1.2 Root and Gplay
Try it.... If it does fix netflix, I will make a ROM using it.
bob"Pzebacz im, bo nie wiedzą, co czynią"
No go. Still working on the fix.
Originally posted by Finless View PostTry it.... If it does fix netflix, I will make a ROM using it.
bob
Bummer.
The update was over 300mb, which makes me think it wipes everything clean and starts fresh with the fix. Why else would this "update" be 300mb if not to hold the entire OS on it.
Great deal
I got this little sucker at Big Lots today for $89 seems like a great deal especially since you rooted it for us Bob thanks a bunch buddy you really made my day Sir! I notice a lot of apps say aren't compatible with this version is there a way to fix this? No big deal just checking. Thanks again Bud very much appreciated.
Ps... I see some of my answers in the thread, sorry for the post.Last edited by LibertyMonger; 26 July 2012, 01:08.
Forced touch calibration after battery power loss.
Is anyone experiencing forced touch calibration after the battery runs dry? If I power down the tablet manually and boot it back up there is no touch calibration. However if the battery runs dry which forces the tablet to shutdown, then I plug in the power adapter which turns the tablet back on automatically, I am presented with the touch calibration.
Unfortunatly that is life with a resistive screen. If it does not feel it was powered down right it forces calibration next boot.
Don't freeze calibration!
Originally posted by Finless View PostUnfortunatly that is life with a resistive screen. If it does not feel it was powered down right it forces calibration next boot.
I first reset my tablet with the pinhole BEFORE freezing calibration. Turned my tablet back on and was presented with calibration. Second time I FROZE calibration, reset with pinhole and turned the tablet on. After that weird things happened. First all my touches were mirrored. Luckily I had "show pointer" on in settings so I knew where my pointer was actually registering on the screen and they were not where I was touching. Then the bootloader image appeared for a couple seconds like it was rebooting but it didn't which was odd. I was able to eventually boil calibration, reboot and everything was back to normal with the lovely calibration screen.
So apparently the calibration config file gets deleted, reset or whatever when the tablet gets improperly shutdown. So bottom line just don't mess with the calibration. Yeah its stupid but it beats the alternative.
Go Launcher not autoloading upon boot
I just wanted to throw this out there in case anyone else is having this issue. I wanted to use a different launcher, Go Launcher to be exact. I made it my default launcher. However every time when I rebooted my device I would always get a black home screen and when I touched the home button Go Launcher would then appear. I figured the stock launcher and Go Launcher were fighting resulting in no home screen loading. So I froze the stock launcher, rebooted and problem solved. I have not tested if this happens with other launchers but I assume freezing the stock launcher will produce similar results.Last edited by FreakAZoid; 27 July 2012, 17:19.
Originally posted by jerryd333 View PostHi all. I just downloaded this rom and there was no readme file. Is there a link to install instructions?
@ Finless Bob... THANK YOU! For sharing your time and effort with us! You are much appreciated!
Originally posted by Herbgirl View PostI just downloaded it yesterday and flashed today (without a hitch). ReadMe was in there. Try re-downloading.
When you click that you now need to click run
Sent from my SK17i using Tapatalk 2Please consider donating to purchase tablets for Finless Bob to continue his work. This will help in the creation of custom roms and build an even stronger development base for our community. Thank you for you support!
</form>
Try putting it into recovery again. Select the loader at the top of the flash screen . Click erase Idb that should complete in about 30 seconds. Than click run to flash
I presume when you are on the flash screen it says found rk android at the bottom
</form>
There are currently 1711 users online. 0 members and 1711 guests.
