Don't plug in device....download USB deview. Run. Remove anything that looks like it was just installed so the comp will want to look for drivers. Point it at your rk2918 drivers folder. Windows should see it as rock usb device. Don't forget to check usb debugging, mock locations doesn't hurt either. Now you should be abe to reset and rk tool should say found.
KID™IDAHO tapatalk
