Pipo M8HD RileyROM 1.6 KitKat
    I dunno why, but with the screen off the stock alarm doesn't work, and starts when I turn on the screen. Anybody faced this problem?
      Originally posted by Taajan
      So I had something weird happened. I tried to flash the new twrp update but apparently it didn't work because the recovery still says 6.xxx. But so far my screen has not been flickering since. The kernel tweaker software I like to use didn't work at first until after trying to flash
      Sent from my M8HD using Tapatalk
      May be it's some kind of kernel issue? Incorrect voltage setting or something else in rileyrom 1.6?
        Who can make the kernel to version 1.6? My tablet version 1.3.1 works best with-kernel_cpu1704h_gpu600_ddr720stockvolt.img CPU voltage undervolted. Sorry for bad English (translated by Google)
          Re: Pipo M8HD RileyROM 1.6 KitKat
          Question, the children apps on this tablet that comes with the stock ROM, is it possible to install those on another tablet? I would love to install the launcher but I heard that one did have a license
          Sent from my BLU Life View using Tapatalk
          I really don't think you can get those Pipo apps to work on anything other than a Pipo tablet.
          Randy
            I really like my U8.
            Randy
              Taajan, could tell what exactly you did? Cause I flashed last TWRP version to my tablet but flickering is still present. TWRP 2.7 works fine. I backed up my tablet to sd card.
                Originally posted by abdul_pt View Post
                Updated the TWRP for the M8HD. You will find it here. Please report back.
                Expect some screen refresh problems, like when you select a button he get's highlighted but the screen freezes, in this case press a fisical button and the screen will snap off it.
                I'm working on solving this issue, but it doesn't occur on my tablet.
                Hello abdul,
                i've flashing my tablet with this next version.
                It seem more stable than previous
                I can select, without any problem, partitions... and navigate into them.
                And select is more efficient!
                "Just ATP"
                - MTKZenyT(ools) : Tools to backup, flash, root'n unroot under GNU/Linux
                Phone: Xiaomi Redmi 1
                Tablet
                s: CDisplay SV1.0.6 (original); PiPo M8HD (under RileyRom 1.9)
                  Nice to hear that.
                  Thank's for the feedback.
                  But i have mad news, i will do another update because i was experience some problems with wipping(format), don't know if you experience that.
                  One of the downside's of being on the newest version's is that sometime's things are not as we like it.
                  tapatalked
                  if [ $up.post.type = $type.two.lazy.to_use_google ] || [ $up.post.type = $type.silly_question ];
                  then mv $user.contact.up.post /.trash; set response($response.type = ignore);
                  $user.up.post.ignore_in_future = true; fi;
                    Taajan,
                    Are you the only one who seems to have that flicker? I haven't seen anyone else mention it.
                    Randy
                      It seems to me these guys also have flickering problem:
                      pappinait
                      mezzo
                        You think is related to the TWRP ?
                        Try flashing the generic TWRP and see if the problem persists.
                        Maybe you could check serial number's and see if you have all the same batch, and maybe exists some differences between model's.
                          Abdul, are you using the current kernel?
                          Randy
                            Yes. From this thread.
                              My serial number is M8HDN1311G0177.
                              No, it is not related to TWRP. Flickering exists with or without TWRP installed.
                                I don't know what the difference would be. But I also don't know what Pipo did to fix the flicker in this version...
                                Randy
