Kitkat Kernels for All (well most!)
I was testing this kernel_t_AP6210-alt_SD_v310.img. Stick wont boot after flashing. And then this kernel_t_AP6210-alt_HD_v310.img. Both wont reboot after successfull flash. If u flash the same kernel again it will probably boot. Or when the flash is done u have to unplug and plug it back more times to make it work.
3.10a works as it should, this ...
- GPU overide for T kernels now possible (450 limit removed)
- DDR override fixed (PLL limit to 445 removed)
... is missing in the kernel.cx-919ii
Originally posted by digger View PostDear d33,
Here is what I've found out about combinations in settings concerning the LAN/wifi mutual switching.
Situation 1.
-LAN On and WIFI Off>reboot>LAN is picked up and WIFI is disabled-O.K.
Situation 2.
-LAN Off and WIFI On>reboot>LAN is unconnected and WIFI is picked up-O.K.
Situation 3.
- LAN On and WIFI On>reboot>LAN is unconnected and WIFI is searching for Wi-Fi network but can't find it. In this situation when I switch off both LAN and wifi then I can switch them on separately.
What combinations of settings would you prefer for DMESGs I can make?
And also I have some tiny, not too important for now details which I wouldn't like to distract you with. I'll inform you after we(users) do main tests.
Kind Regards
Please don't pay your attention to my post above. I suspect this misunderstanding with LAN/wifi switching algorithm was caused by KK ROM I tested your kernels with. I have just returned back to a928_4.4.2_kk_finless20 and I feel some positive differences. I'll test all things again and inform you tomorrow.
Have a good sleepCS918II/16GB(HTC-031-V1.0 board)
CS918 (TN-BX09_V2.1 2013/05/31) FW: k-r42-old_revision-wasser-1.2.3- fried by 12V PS
K-R42 board version B351_V2.0 1348, wifi Realtek8188ETV , RK3188T;FW: wasser-firmware-kr42-new-1.0.3
D33, is the overclock script compatible with the kernel on bob's A928 rom? I believe you helped with unlocking that kernel as well.
Anyway, I tried to overclock that kernel using your script but it seems to OC the CPU only (based on antutu benchmark, don't know how to verify GPU and DDR clock).
Your kernel (from this thread): 1.7ghz cpu, 798gpu, ddrstock = 189XX antutu score
Kernel from Bob's rom: 1.7ghz cpu, 798gpu, ddrstock = 172XX antutu score
Stock OC Kernel from Bob's rom: 1.6ghz, gpu unknown, ddr unknown = 17,7XX antutu score
Re: Kitkat Kernels for All (well most!)
Originally posted by peekeesh View PostD33, is the overclock script compatible with the kernel on bob's A928 rom? I believe you helped with unlocking that kernel as well.
Sent from my Nexus 7 using Tapatalk
Hi Noderat,
Would you be so kind to patch for OC new package of d33's kernels V3.1(TV Boxes)
RTL8188(3.11a) from post#1 which have been released few hours ago?
Thank you in advanceCS918II/16GB(HTC-031-V1.0 board)
Sent from my mobile device. Please excuse any typos.
Originally posted by noderat View PostYes I will patch and release shortly.
Sent from my mobile device. Please excuse any typos.CS918II/16GB(HTC-031-V1.0 board)
It seems that the overclock script on bob's kernel doesn't work. The gpu doesn't get Overclocked. only the cpu and ddr gets patched. Not sure why.
Sent from my SPH-L900 using Tapatalk
Originally posted by peekeesh View PostHey bud, i checked dmesg and was able to confirm the freqs. Thanks!
Originally posted by noderat View PostBecause that's why there is a v3 of d33 kernel to remove those locks.
Originally posted by peekeesh View PostOk. Yea d33's kernel work great but it loses video signal after leaving the box on for hours. Even when not overclocking the kernel at all....
Who knows, maybe d33 has a timer included. After hours of not using it shuts down automatically.
D33 im ready to test some fixed or new kernelscx-919ii
Originally posted by Max One View PostI can confirm that. Stupidly i forgot to turn off my tv stick, so it was on the whole night. This morning i saw its on and after powering on the tv there was no signal.
D33 im ready to test some fixed or new kernelsLast edited by jacobsson; 02 April 2014, 14:38.PIPO-P1@1.6GHz
ROM: RileyROM 1.7CX-919@1.9GHz/798MHz/800MHz
ROM: Finless 4.4.2 BETA
Kernel: D33's AP6210 HD v3.00 +noderat OC
Fan mod: Outside & inside + Antutu: 23694 & Stability test
Originally posted by Max One View PostI was testing this kernel_t_AP6210-alt_SD_v310.img. Stick wont boot after flashing. And then this kernel_t_AP6210-alt_HD_v310.img. Both wont reboot after successfull flash. If u flash the same kernel again it will probably boot. Or when the flash is done u have to unplug and plug it back more times to make it work.
Edit: Bluetooth worked after a reboot. But bluetooth seems to be interfering a lot with my wifi signal when playing XBMC over SMB/locally.Last edited by roooii; 02 April 2014, 14:24.
There are currently 4799 users online. 1 members and 4798 guests.
