Sent from my SPH-L900 using Tapatalk
Kitkat Kernels for All (well most!)
Originally posted by noderat View PostMaybe we could throw together a wiki or find one that we could update with all this info on kernels/hardware mods for the different TV sticks and boxes.Tronsmart Orion R68 Meta
CS968 -> HTC_T018 v4 20131216 with MTK
GM282 (aka CX 919 II aka J22) - dead
As mentioned on another thread I've bricked my TV Box playing with the new Rockchip official ROM and can't revive it until I get home.
In the meantime these where my latest test buildsLast edited by d33; 02 April 2014, 20:21.Measy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Originally posted by peekeesh View PostI've tried that and mine doesn't wake up after clicking buttons on the air mouse or after waving it. I guess it differs per device? I have a tronsmart a928. What do you have?
On a side note, I have noticed that my stick does get hot when playing 1080p even when using "kernel_AP6210-J22_HD_v300_cpustock_gpustock_ddrstock".
So question is, do these set of HD kernels necessitate an external fan to be used always? (I do not have one yet.)Tronsmart Orion R68 Meta
Needs .zip on end
Sent from my iPhone using TapatalkMeasy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Originally posted by ghanashyaml View PostThe link does not seem to work. This build bricked your box?
Also, I cannot find the "310a" builds that Max One/rooii have tried. Did you remove that build?
Yes removed
Donate to Finless
Originally posted by d33 View PostRom bricked it not kernelTronsmart Orion R68 Meta
Hi d33,
As I promised yesterday concerning swithcing between LAN and wifi using V3.11a...
Both LAN and wifi work great separately.
I checked it with a928_4.4.2_kk_finless20 ROM with your kernel_RTL8188_HD_v311a.
This combination works more correctly in compare with that I tried before with another KK 4.4.2.
But what I noticed is:
1)Initially, I have LAN switched ON(with icon showed) in settings and wifi switched OFF, then I switch ON wifi, system shows me wifi icon and connecting>obtaining IP address>disabled -it's correct(LAN remains to be working). Then I remove ethernet cable from socket and connect it again. LAN doesn't appear and system says Unconnected, but it must switch OFF wifi and switch ON LAN in case it works properly.
2)Initially, I have LAN switched ON(with icon showed) in settings and wifi switched OFF, then I switch ON wifi, system shows me wifi icon and connecting>obtaining IP address>disabled -it's correct(LAN remains to be working). Then I reboot device and system shows me wifi icon only, wifi is Searching for network but can't find it, there is no LAN icon and system says that LAN is Unconnected. But LAN should have been working and wifi must be disabled(because LAN has main priority).
Another thing were noticed...
When I turn on Power button, system boots, shows me your bootanimation not in the center but left up side..Finless' screen..initial android screen, but screen size is smaller(there is black frame around the screen), in about one minute image takes correct size. During this "adjusting" time sound doesn't work.
And last a little bit more important...
When device works and I disconnect HDMI cable from TV, the Power LED changes from blue to red. Then I connect cable to TV, the Power LED becomes blue, but there is no TV signal. Reboot helps only.
When device works and I press Power button,the Power LED changes from blue to red, TV screen becomes black. Then I press Power button,LED becomes blue, but TV signal doesn't appear.
These were negative details I could find so far, but for now kernel works great and it's stable with my board revision and the most important fact is YOU OVERTHREW 3188T!!!CS918II/16GB(HTC-031-V1.0 board)
CS918 (TN-BX09_V2.1 2013/05/31) FW: k-r42-old_revision-wasser-1.2.3- fried by 12V PS
K-R42 board version B351_V2.0 1348, wifi Realtek8188ETV , RK3188T;FW: wasser-firmware-kr42-new-1.0.3
I'm drawing a close to this development. These were beta sources and flawed. With the help of Wasser and others I've been able to get them nearly right.
I don't think there's much more to get out of this, let's see what happens nextMeasy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Originally posted by d33 View PostI'm drawing a close to this development. These were beta sources and flawed. With the help of Wasser and others I've been able to get them nearly right.
Do you think that it's impossible to overcome HDMI signal lossing when divice wakes up after sleeping?CS918II/16GB(HTC-031-V1.0 board)
Originally posted by digger View PostI understand you concrening beta sources.
Do you think that it's impossible to overcome HDMI signal lossing when divice wakes up after sleeping?PIPO-P1@1.6GHz
ROM: RileyROM 1.7CX-919@1.9GHz/798MHz/800MHz
ROM: Finless 4.4.2 BETA
Kernel: D33's AP6210 HD v3.00 +noderat OC
Fan mod: Outside & inside + Antutu: 23694 & Stability test
There are currently 1829 users online. 1 members and 1828 guests.
