Kitkat Kernels for All (well most!)
Originally posted by digger View PostMeasy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Originally posted by d33 View Post1. See post #1
2. see post #2
Noderat, in your post, you mention "v3.10 for TV boxes".
Does that mean it has more overclocking not suitable for TV sticks?.
I am using D33 v3.10 with TV stick CX919II.Tronsmart Orion R68 Meta
CS968 -> HTC_T018 v4 20131216 with MTK
GM282 (aka CX 919 II aka J22) - dead
Originally posted by noderat View PostWhoops! Okay guys I shouldn't do work at 4am. It's fixed now.
Antutu: 22841
kernel_AP6210_HD_CIFS_cpu1800h_gpu798h_ddr720
Antutu: 22745
kernel_AP6210_HD_CIFS_cpu1800h_gpu798h_ddr800
Antutu: 23043
kernel_AP6210_HD_CIFS_cpu1920h_gpu798h_ddr800
Antutu: 23694
Thanks man!
Update: Stability test cleared 100%, BT and WIFI working!Last edited by jacobsson; 01 April 2014, 09:02.PIPO-P1@1.6GHz
ROM: RileyROM 1.7CX-919@1.9GHz/798MHz/800MHz
ROM: Finless 4.4.2 BETA
Kernel: D33's AP6210 HD v3.00 +noderat OC
Fan mod: Outside & inside + Antutu: 23694 & Stability test
As I can see you sent me "_t_" version.
I tried your "_t_" V.3.1 before but they didn't too.
kernel_RTL8188_HD_v3.10 and kernel_RTL8188_HD_v3.10_cpu1800h_gpu798h_ddr720(OC ed by Noderat) do boot, but no Ethernet and sound issues.
Would you be so kind to compile not "t" sample?CS918II/16GB(HTC-031-V1.0 board)
CS918 (TN-BX09_V2.1 2013/05/31) FW: k-r42-old_revision-wasser-1.2.3- fried by 12V PS
K-R42 board version B351_V2.0 1348, wifi Realtek8188ETV , RK3188T;FW: wasser-firmware-kr42-new-1.0.3
Originally posted by digger View PostI have just had a try. It doesn't boot.
Would you be so kind to compile not "t" sample?Measy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Originally posted by digger View PostSorry, but doesn't boot
With VMAC switched on - no boot
Back to VMAC switched off - Boots
Looks like no easy ethernet for 8188Measy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Can I make any additional logs? Or some terminal commands?CS918II/16GB(HTC-031-V1.0 board)
Originally posted by digger View PostDo you mean switching among the ethernet chip and wifi(RTL8188)?
Can I make any additional logs? Or some terminal commands?Measy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
D33, can you tell me why the voltage is different between JB overclokomatic and KK overclokomatic? If i look at the gpu, ddr profiles of JB compared to the gpu, ddr profiles of KK u see that KK has higher voltage.
Should it not be the same as in JB script?
Edit: Sry my bad. The gpu voltages seems to be the same but the ddr voltages are definitely
not.cx-919ii
I have just remembered the same situation with ethernet swithcing issue in wasser's 4.2.2 roms for boxes like mine.
I don't know whether this part of KK config is similar to JB or not.
If it is correct way for you, you'd better ask wasser. I can too, but I'm sure you'll find more appropriate wordsCS918II/16GB(HTC-031-V1.0 board)
Originally posted by Max One View PostD33, can you tell me why the voltage is different between JB overclokomatic and KK overclokomatic? If i look at the gpu, ddr profiles of JB compared to the gpu, ddr profiles of KK u see that KK has higher voltage.
Should it not be the same as in JB script?Measy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Re: Kitkat Kernels for All (well most!)
Sent from my mobile device. Please excuse any typos.
Big thanks for these kernels!
3 questions:
1: Can I overclock just by trying which kernel does boot, or is heating also an issue? I tried to OC my MK908II to 1.6, it worked, but it became really hot. Is this a problem, or can I brick it by overheating?
2: I tried to remove the heatsink by heating with an hairdryer, but could not get it done. I mailed Geekbuying, hope they can tell if I have a T-version. Can I find out by flashing? I mean: will a T-kernel work on a non-T chip and vice versa?
3: I have visual flickering/glitches in the ROM. I've read this is a known bug, but could not find if any solution has been posted? (it might be ROM-related).
Originally posted by d33 View PostIt wouldn't hurt. I don't remember changing them. If I did it was just to match the stock frequencies/voltages in th kk beta sources.
Thx in advance
Edit: I know in kk beta source as u said but is it somewhere written?cx-919ii
There are currently 1631 users online. 1 members and 1630 guests.
