Kitkat Kernels for All (well most!)
I downloaded the script and re-downloaded the kernel (so exactly the same as you guys) to a clean area and executed. All worked fine, so I've no idea why not working for you. Sorry.
C:\Users\Darrell\Downloads\test_script>perl overclockomatic_kk.pl kernel_t_AP6210_SD
v207.img
Rockchip Patchomatic Suite
Overclockomatic RK3188 v1.2
by phjanderson
Reading kernel image
Done!
Searching GPU frequency limit cap
Found: 133000000, 600000000
Patching...
Searching volt/frequency tables
Done!
Volt/frequency tables found in the image:
== Table 1 at offset 9947136 ==
MHz mV
816 1000
== Table 2 at offset 9950800 ==
MHz mV
500 1100
== Table 3 at offset 9950824 ==
MHz mV
180 1150
300 1100
400 1150
500 1200
== Table 4 at offset 9950864 ==
MHz mV
200 1000
300 1050
400 1100
500 1150
600 1200
== Table 5 at offset 9950912 ==
MHz mV
816 1050
== Table 6 at offset 9952952 ==
MHz mV
312 900
504 925
816 1000
1008 1075
1200 1200
1416 1250
== Table 7 at offset 9953008 ==
MHz mV
133 975
200 1000
266 1025
300 1050
400 1100
600 1250
== Table 8 at offset 9953064 ==
MHz mV
200 950 1 DDR_FREQ_SUSPEND
528 1250 256 DDR_FREQ_NORMAL
== End of tables ==
Please identify the CPU, GPU and DDR table. Press ctrl-c to cancel.
Which table is the CPU table?
(The CPU table is mostly the largest table ranging from 312 to 1608 MHz)
6
Which table is the GPU table?
(The GPU table is mostly the second largest table ranging from 133 to 600 MHz)
7
Which table is the DDR table?
(The DDR table is mostly quite short, mostly 2 entries, and can be recognized b
the labels DDR_FREQ_... at the end of each line)
8
Patching kernels... please wait...
Writing kernel_t_AP6210_SD_v207_cpu1920h_gpustock_ddr667.i mg
Writing kernel_t_AP6210_SD_v207_cpu1920h_gpustock_ddr720.i mg
Writing kernel_t_AP6210_SD_v207_cpu1920h_gpustock_ddrstock .img
Writing kernel_t_AP6210_SD_v207_cpu1920h_gpustock_ddr800.i mg
Writing kernel_t_AP6210_SD_v207_cpu1920h_gpu798h_ddr667.im g
Writing kernel_t_AP6210_SD_v207_cpu1920h_gpu798h_ddr720.im gMeasy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Works well for me, I imagine it may have something to do with your perl installation.
Sent from my mobile device. Please excuse any typos.
Originally posted by noderat View PostWorks well for me, I imagine it may have something to do with your perl installation.
C:\Users\Darrell\Downloads>perl -v
This is perl 5, version 16, subversion 3 (v5.16.3) built for MSWin32-x64-multi-t
hread
(with 1 registered patch, see perl -V for more detail)
Copyright 1987-2012, Larry Wall
Binary build 1603 [296746] provided by ActiveState http://www.ActiveState.com
Built Mar 13 2013 13:31:10Measy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Re: Kitkat Kernels for All (well most!)
hread
I'm now seeing the table contents and they match the guidance from the script, but I get an error at the end.
Code:D:\MK908ii\RKPatchomatic>perl d33revisedoverclockomatic3188 kernel_t_AP6210_HD_v207.img ============================= Rockchip Patchomatic Suite Overclockomatic RK3188 v1.2 by phjanderson ============================= Reading kernel image Done! Searching GPU frequency limit cap Found: 133000000, 600000000 Patching... Searching volt/frequency tables Done! Volt/frequency tables found in the image: == Table 1 at offset 9947136 == MHz mV 816 1000 == Table 2 at offset 9950800 == MHz mV 500 1100 == Table 3 at offset 9950824 == MHz mV 180 1150 300 1100 400 1150 500 1200 == Table 4 at offset 9950864 == MHz mV 200 1000 300 1050 400 1100 500 1150 600 1200 == Table 5 at offset 9950912 == MHz mV 816 1050 == Table 6 at offset 9952952 == MHz mV 312 900 504 925 816 1000 1008 1075 1200 1200 1416 1250 == Table 7 at offset 9953008 == MHz mV 133 975 200 1000 266 1025 300 1050 400 1100 600 1250 == Table 8 at offset 9953064 == MHz mV 200 950 1 DDR_FREQ_SUSPEND 528 1250 256 DDR_FREQ_NORMAL == End of tables == Please identify the CPU, GPU and DDR table. Press ctrl-c to cancel. Which table is the CPU table? (The CPU table is mostly the largest table ranging from 312 to 1608 MHz) 6 Which table is the GPU table? (The GPU table is mostly the second largest table ranging from 133 to 600 MHz) 7 Which table is the DDR table? (The DDR table is mostly quite short, mostly 2 entries, and can be recognized by the labels DDR_FREQ_... at the end of each line) 8 Patching kernels... please wait... ERROR: DDR profile table ddr667 is larger than the DDR table in the kernel D:\MK908ii\RKPatchomatic>
Originally posted by tinyhands View PostThe first combination I tried was kernel_t_AP6210_HD_v207 with Bob's patched boot1080_large. This gave me an Antutu score of 17372. Sound did not work at first, but came on after a bit. Wish I could say there was something specific I did. Wifi was good, SD videos stream nicely from my NAS, and Netflix was very good. I left the stick running for a couple hours while I went out to dinner and when I came back the sound was choppy to the point of being unusable. I don't know if this was perhaps a heat-related issue, but the stick did not feel overly warm.
After experimenting with these kernels, I flashed JellyBean to test the kernel from the blacklist thread. You know how that worked out. So I came back to this combination and audio was choppy again. I reflashed just the kernel and the system.img and audio was fixed. I let it run on Netflix for 30 minutes or so and it got pretty hot, possibly still safe but hot enough to make me nervous. I've shut it down and haven't done anything with it until I potentially figure out a patchomatic option that runs cooler.
Originally posted by marko33 View PostD33 Is it possible to up the voltages for cpu, i want to try and get my t chip stable at 1700, latest kernel working very well by the way - mk908ii. Thanks.
If you can't get a stable 1.7 GHz using the kernels I published + overclockomatic then I fear that is the way it is. In terms of making a difference DDR >> CPU >> GPU.Measy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
ok D33 thanks for your help, its only when i set governer to performance and run linpack i get a lockup, if i leave governer on interactive all is fine, cpu 1704 gpu stock ddr 720 using overclockomatic_kk on v2.07 kernel. just wondering if you can shed some light on the problem with cifsmanager while your online - see a928 thread
Originally posted by marko33 View Postjust wondering if you can shed some light on the problem with cifsmanager while your online - see a928 threadMeasy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Originally posted by tinyhands View PostI then proceeded to load kernel_t_AP6210_SD_v207 with boot1080_large = 16507 (all ok)
kernel_t_AP6210_SD_v207 with boot720 = 16472 (minor screen blinking)
Clearly the rotation-lock impacted the other scores, but it should be proportional, so I still think I'm running the best of the bunch.
I was wrong about HD207/boot1080 being the fastest combination of the bunch. SD207/boot1080 should've been, and actually was faster when I loaded it and ran Antutu without the rotation-lock enabled. But this build doesn't have the softkeys onscreen. I googled & inserted qemu.hw.mainkeys=0 to the last line of the build.prop, but can't get them enabled. Without downloading & installing a persistent application, is there a way to natively turn on softkeys in build #190 as they are in #191?
Hi D33,
I'm running into a problem with your AP6210 SD T kernel.
I've used PHJANDERSON's overclock script to patch it, the script finishes without issues but the ram and gpu overclock don't seem to be working.
I've not tested the gpu overclock in depth so I'll leave that aside for now but the ram on the other hand is showing some strange behaviour.
As shown below it looks like it's resetting the ram frequency back to 445 Mhz for some reason.
Can you please take a look at this?
Thank you very much in advance.
Best regards
Code:root@m0:/mnt/internal_sd # dmesg | grep ddrfreq <6>[ 2.060039] ddrfreq: verion 3.2 20130917<6>[ 2.060073] ddrfreq: fix cpu pause bug<6>[ 2.060109] ddrfreq: normal 720MHz video 0MHz video_low 0MHz dualview 0MHz idle 0MHz suspend 198MHz reboot 222MHz<6>[ 2.110059] ddrfreq: change freq to 445 MHz when normal
Looking for cpu1.6GHz, ddr 800, gpu whatever
Originally posted by Pihkal View PostThanks for your awesome kernel D33, I'm using it on my CX919 (T) and it's working great.
Patched your T-kernel with overclockomatic_kk and now run at 1.6Ghz with close to 19000 antutu points.
Everything works, no stuttering or anything.
Thanks a million!
There are currently 3293 users online. 1 members and 3292 guests.
