Kitkat Kernels for All (well most!)
Originally posted by marko33 View PostJust used the overclockomatic_kk script to overclock the AP2610t kernel to 1604, works ok but only have 3 steps for frequency now, is this normal.
If you want the full compliment then just amend script.
Sent from my iPhone using TapatalkMeasy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Originally posted by Max One View PostMy cx 919ii has a rk3188T cpu. Is it possible to overclock the ram or are they locked? Im only able to overclock the cpu nothing else
Donate to Finless
Originally posted by d33 View PostMy kernels are CPU and DDR RAM 'unlocked'. You can check the DDR used in the DMESG log if you want confirmation
test-kernel-j22_cpu1608h_gpustock_ddrstock or
test-kernel-j22_cpu1608h_gpustock_ddr720.img
Im always getting the same antutu score thats why i have asked. Normally the antutu score should be higher with a overclocked ram. Am i right?
rb1213....
also the HDMI zoom feature seems to be not working and the screen is 3% to big to fi on my panny tv !
ciao
cx-919ii
I'll release a 2.01 version tonight to fix all the above
Donate to Finless
Im always getting the same antutu .Measy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Originally posted by d33 View PostWierd. Did you check DMESG to ensure the RAM speeds are different?cx-919ii
Just search for "ddrfreq:"
eg
ddrfreq: normal 528MHz video 0MHz video_low 0MHz dualview 0MHz idle 0MHz suspend 198MHz reboot 222MHz
Donate to Finless
Ok, found that sentence in test-kernel-j22_cpu1608h_gpustock_ddrstock.img. Now i will flash the oc kernel.
Found also a sentence: ddrfreq: change freq to 445 mhz when normal. Whats the meaning of?
Antutu scores about 17800.
In the overclocked kernel test-kernel-j22_cpu1608h_gpustock_ddr720.img,
i found ddrfreq: normal 720MHz video 0MHz video_low 0MHz dualview 0MHz idle 0MHz suspend 198MHz reboot 222MHz
Antutu scores about 18000
I gained only 200points, thats really weak. Should it be more?Last edited by Max One; 17 March 2014, 20:58.cx-919ii
Originally posted by d33 View PostTHis is from my 't' device running at 1800 CPU / 720 DDR (AnTuTu - 20,500)
<4>[ 0.733989] efuse_version_val: efuse version = 51
<4>[ 0.734035] DVFS MSG: core: dvfs_adjust_table_lmtvolt get leakage_level = 6000
<4>[ 0.734099] adjust table freq=1800000 KHz, index=1375000 mV to index=1350000 mV
<4>[ 0.734207] efuse_version_val: efuse version = 51
<4>[ 0.734252] DVFS MSG: aclk_gpu: dvfs_adjust_table_lmtvolt get leakage_level = 6000
<6>[ 0.735174] CPU is ROCKCHIP RK3188T
<6>[ 0.735210] NEOMODE the eFuses are (22) = 2b and (23) = 2
<4>[ 0.749928] efuse_version_val: efuse version = 51
<4>[ 0.749973] DVFS MSG: core: dvfs_adjust_table_lmtvolt get leakage_level = 6000
<4>[ 0.750035] adjust table freq=1800000 KHz, index=1400000 mV to index=1350000 mV
<4>[ 0.750101] efuse_version_val: efuse version = 51
<4>[ 0.750145] DVFS MSG: aclk_gpu: dvfs_adjust_table_lmtvolt get leakage_level = 6000
<6>[ 0.751066] D33Info: CPU is ROCKCHIP RK3188T
<6>[ 0.751108] D33Info: eFuses are set to (22) = 2b and (23) = 2
My antutu scores 19200. The question why is my score so low? Its exactly the same as yours.cx-919ii
There are currently 2344 users online. 0 members and 2344 guests.
