Kitkat Kernels for All (well most!)
    THis is from my 't' device running at 1800 CPU / 720 DDR (AnTuTu - 20,500)
    <4>[ 0.733989] efuse_version_val: efuse version = 51
    <4>[ 0.734035] DVFS MSG: core: dvfs_adjust_table_lmtvolt get leakage_level = 6000
    <4>[ 0.734099] adjust table freq=1800000 KHz, index=1375000 mV to index=1350000 mV
    <4>[ 0.734207] efuse_version_val: efuse version = 51
    <4>[ 0.734252] DVFS MSG: aclk_gpu: dvfs_adjust_table_lmtvolt get leakage_level = 6000
    <6>[ 0.735174] CPU is ROCKCHIP RK3188T
    <6>[ 0.735210] NEOMODE the eFuses are (22) = 2b and (23) = 2
    Donate to Finless
      Temporary link to a test kernel for those that want camera support
      It is a 'T' override kernel clocked to 1.6 / 667 so may not be stable on some T kernels.
      Test you cameras and let me know if any work.
      Make / model / chipset would be useful
      Donate to Finless
        Originally posted by vkk View Post
        Thank you!
        The old wifi sticks dont get much love lately (understandably so).
        Anyone tested it on mk802iv or similar sticks with old wifi?
        My parents are using the stick and I cant really let them test it.
        Yes I have mk802iv with rtl8188eu (old wifi) and d33 made kernels for this config (post #1) for my request or if You wanna You can check my kernels tested directly by me on these stick.
          ignore
            You mean you tested them and they are stable for daily usage?
            No crushes, reboots, FC, smooth video etc?
            If you can upload yours that would be awesome
              Re: Kitkat Kernels for All (well most!)
              Originally posted by d33 View Post
              It seems to suggest it detected two partitions; SDA1 and SDA2 with the second containing a logical partition SDA5. What does "fdisk -l /dev/sda" give?
              Looks to me to be ROM related, not kernel?
              Using my ipad so apols for any stupid ios spelling 'corrections'
              Thanks for interest, i will look up later today, after work!
              Sent from my HTC One
                AW: Kitkat Kernels for All (well most!)
                Man... You belong to ROM Developers group and You messed up units please correct these KHz
                Thanks for your advice, yerzu.
                JDfense --->I8160
                  Thanks for everything d33.
                  Just got a CX919 very cheaply, but to my disappointment it is a T model.
                  The CPU not hitting the dizzy heights of 1.9ghz I can live with, but when my overclocked mk808 can run XBMC in native 1080p at 60fps, yet my CK919 can only 40fps it is disappointing to say the least.
                  Your efforts are appreciated. I hope the GPU situation gets sorted out for all involved.
                  Currently Using:
                  2 x Nvidia Shield TV | MiniMX III
                  Retired Devices:
                  MiniMX III-II | Mk808b Pro | Mk808b Plus | Raspberry Pi 1 + 2 | UBOX R89 | MK808 | MK808b | CS008 | X1 4K (rk3288_809) | CYX_809III | Ouya | CX-919 | S82 Plus | Tronstmart R68
                    What's the maximum CPU / DDR frequencies you have managed to get on your device?
                    Can you post your best, stable result along with the leakage level bit from DMESG?
                    Donate to Finless
                      I believe I was hitting 1.6ghz comfortably, didn't push it too much since CPU overclocking isn't my main gripe as it will be used purely as a XBMC device, even underclocked it's overkill for it. I don't mind testing a few kernels however, as they are so much easier to flash with the button on the side.
                      I will post results from DMESG and do some more testing when I get a chance at some point, the least I can do considering your efforts.
                      Currently Using:
                      Retired Devices:
                          <4>[ 0.739474] DVFS MSG: core: dvfs_adjust_table_lmtvolt get leakage_level = 5000
                          <4>[ 0.739539] adjust table freq=1800000 KHz, index=1375000 mV to index=1350000 mV
                          <4>[ 0.739609] efuse_version_val: efuse version = 51
                          <4>[ 0.739652] DVFS MSG: aclk_gpu: dvfs_adjust_table_lmtvolt get leakage_level = 5000
                          <6>[ 0.740560] CPU is ROCKCHIP RK3188T
                          <6>[ 0.740596] NEOMODE the eFuses are (22) = 2b and (23) = 1
                          <4>[ 0.740975] rk3188 cpufreq version 2.2, suspend freq 1200 MHz
                          Max stable like for many others is 1.6ghz.
                          Currently Using:
                          Retired Devices:
                            Thanks for that - not seeing an obvious correllation between performance and leakage level/eFuse yet but perhaps it will be more apparent when more people post their results.
                            Donate to Finless
                              This is my results:
                              u0_a94@m0:/ $ su
                              root@m0:/ # fdisk -l
                              root@m0:/ # fdisk -l /dev/block/sda
                              Disk /dev/block/sda: 500.0 GB, 500074283008 bytes
                              255 heads, 63 sectors/track, 60797 cylinders
                              Units = cylinders of 16065 * 512 = 8225280 bytes
                              Device Boot Start End Blocks Id System
                              /dev/block/sda1 * 2 1986 15944481 7 HPFS/NTFS
                              /dev/block/sda2 1987 60798 472393247+ f Win95 Ext'd (LBA)
                              /dev/block/sda5 1987 60798 472393216 7 HPFS/NTFS
                              root@m0:/ #
                              Can you tell me this kernel is safe to write: kernel_T_AP6210_HD_cpu1704h_gpu798h_ddrstock.img
                                That isn't the output of fdisk!
                                I cannot tell you anything is safe or not. You must chose.
                                Donate to Finless
