Kitkat Kernels for All (well most!)
    Originally posted by d33 View Post
    Redownload from OP
    no boot
      Originally posted by yerzu View Post
      no boot
      Which kernel? All?
      Post the DMESG of the working one
      Donate to Finless
        Which kernel? All?
        i tried without T sd
          Then try with T version
          ... and post the DMESG
          Donate to Finless
            Ok ... No further feedback and that's the end of the weekend
            Donate to Finless
              T version boot but now I cant test audio (test on my external monitor not on tv)... strange because I have clear 3188 version without T.
              Antutu: 18232 on 720p
              dmesg in attachment dmesg.txt
              Now I see in dmesg that You dont have ASIX ax88179 driver inside.
              How to add power, vol+, vol- buttons next to home back etc. buttons?
              Where I can find KK kernel sources? Actually I have PHJAnderson sources for 3188 from github but this wouldn't work? Or what I must change/add?
                Now tried Fineless KK 2.0 for t428 and no boot only beta2 works and only with T kernel
                suprising i that first test kernel works with kk t428 works but of course without audio
                I checked all: only HD without T boot up.
                  D33, I mk908ii works fine with kernel AR6210 18, but Asics enternet lan 88772b on proezhnemu not supported, could you compile the driver is the core of it, if I need to throw off drivers
                    dmesg in attachment [ATTACH]5613[/ATTACH]
                    From your DMESG:
                    <6>[ 0.718514] usbcore: registered new interface driver ax88179_178a
                    Donate to Finless
                      Support is included. Provide DMESG for debug.
                      Donate to Finless
                        Yes my bad when I run dmesg LAN adapter was unplugged but anyway this driver not work because usb_otg drver is bugged now I go flashing my first KK kernel thanks d33
                          Good Luck.
                          NB. I finished the RTL8188 series this morning. I've added the 1.8v support versions.
                          Donate to Finless
                            Any chance to take a look to your github repo?
                            That way everyonw can compil by themselves and help with changes.
                              Not yet. Code is in constant flux as you can see earlier in thread. Once I've got the tablet stuff sorted I'll make it public
                              The Kitkat beta sources are readily available for download and you can pull my .config from any kernel
                              Donate to Finless
                                Tried your AP6330 kernel. No boot on T428. Since I have the screenflickering it would be very nice to have a 1.8V kernel! Cheers and thanks for the good work.
