I also used two different HDMI cables to rule that out.
Kitkat Kernels for All (well most!)
I experienced the screen flickering issue on my T428 after flashing the Finless 2.0 ROM. I just flashed the new 1080P 1.8 kernel and the flickering persists. I am viewing on a Optoma 1080P projector. I use the recovery partition to hold a Linux kernel and the screen is nice and stable when I boot to the Enlightenment window manager under Debian. Unfortunately Kitkat is impossible to use since the flicker is so bad that my projector ends up blanking the screen most of the time because the signal is so corrupted. It does appear to work fine when connected to a 1680x1050 LCD scaled down from 1080P.
I also used two different HDMI cables to rule that out.T428
Originally posted by wewen View PostTried your AP6330 kernel. No boot on T428. Since I have the screenflickering it would be very nice to have a 1.8V kernel! Cheers and thanks for the good work.
Did you try T ?
Sent from my iPhone using TapatalkMeasy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Yes I tried all the 720 kernels. None of them booted. Went back to KK_RK3188T_720_v01.02. Found out that on my computer screen it doesn't flicker, only on my tv. Is it possible to test KK_RK3188T_720_v01.02 with 1.8V to the HDMI? Since KK_RK3188_720_v01.02 and T version works fine but with flicker.Last edited by wewen; 10 March 2014, 18:10.
I'm confused, wewen says he can't boot the AP6330 kernel on his T428 whilst Mustanley says he can boot fine on his T428!
Donate to Finless
Originally posted by yerzu View Postmaybe wewen have Fineless KK beta2?
Weird!
Using my ipad so apols for any stupid ios spelling 'corrections'Measy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
This seems to be a T428 thing ONLY!
Your kernels work fine on my T428 KK 2.0 ROM on other TV boxes (confirmed on A928 and 921B). They just wont fully boot on the T428. Very strange.
However I know the kernels work because TWRP recovery will boot with them!
Let me try something.......
Be right back.
It could be a tv stick only thing? I'm thinking RK1000 support.Measy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
... But hang on!Wustanley reported his T428 worked on finless KK ROM 2.0.
Donate to Finless
I found the problem!
I had left a logo image in boot.img on my T428 2.0 KK ROM. This is causing the problem on D33's new kernels!
So you T428 guys, I will have 2 new boot.img's posted for you in a few minutes. I have tested it and it works fine. Stay tuned.
Originally posted by mustanley View PostI flashed the new boot_1080 large icons and my T428 continues to boot fine though I still experience the flicker on my 1080P projector
Donate to Finless
So Mr. D., I have begun to test your kernels on my cs968 ap6210.
First kernel I picked with Finless T428 Kitkat is a good start. It was the kernel_T_AP6210_HD.img.
I have still trouble with booting, the old issue. I need power over otg and after booting I need to add the power connection to get keyboard and mouse over usb. Sounds silly, but you can believe me.
After installation, the rom works more fluid than the last one, I check. It seems very stable with 15736 antutu at 1.42 GHz cpu clock.
This time audio and video work fine, bt too. Only ethernet stays still unconnected.Haven't tested AV video or didital audio out. I have no flickering with this kernel.
You are getting very close.I test another version.
JDfense
There are currently 1888 users online. 1 members and 1887 guests.
