Thanks.
Kitkat Kernels for All (well most!)
Guest
Hi D33, I've been using your kernels for a while now in my T stick and I saw that u've created a 1366x768 specific one, is it possible to make a 1024x768 for me ? I can test it on my projector as it's native resolution usually looks much better than any other.
Thanks.
Originally posted by m4f1050 View Postd33, can you compile a kernel with 1080p, o/c and wifi (without any debug stuff or bluetooth stuff) so I can test performance on it?
2. It is o/c - you can change o/c params with script in #2
3. Debug is specific to HDMI/BT start-up and transparent to normal performanceMeasy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Thunderstorm here so will be in the house this afternoon - will have a round-up of all work and try again to get the BT working.Measy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Originally posted by zero_x12 View PostI'm still struggling to get my touchscreen monitor to work.
Is it possible for you to apply the modification in post #2 of the following thread to add touch screen support?
My device ID is 2149:2306 (Advanced Silicon Multitouch). I could perhaps even pay you for your time as I really need touch support!
No need to pay me. If you want to donate please donate to Bob (Finless) for running this amazingly site. There's a link in my signature.Measy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Originally posted by zero_x12 View PostMy device ID is 2149:2306 (Advanced Silicon Multitouch). I could perhaps even pay you for your time as I really need touch support!
Code:[LIST][*]Kernel-3188-X7/drivers/hid/hid-ids.h[LIST][*]added '#define USB_DEVICE_ID_3M2735 0x053f' to USB_VENDOR_ID_3M section, adding new device-id[/LIST][*]Kernel-3188-X7/drivers/hid/hid-core.c[LIST][*]added ' { HID_USB_DEVICE(USB_VENDOR_ID_3M, USB_DEVICE_ID_3M2735) }, ' to USB_VENDOR_ID_3M section[/LIST][*]Kernel-3188-X7/drivers/hid/hid-multitouch.c[LIST][*]added the following entry in 'mt_devices', list of supported devices by the multitouch driver (in the 3M section)[/LIST][/LIST][COLOR=#333333]{ .driver_data = MT_CLS_3M, HID_USB_DEVICE(USB_VENDOR_ID_3M, USB_DEVICE_ID_3M2735) },[/COLOR][LIST][*]Kernel-3188-X7/drivers/input/touchscreen/usbtouchscreen.c[LIST][*]added ' {USB_DEVICE(0x0596, 0x053f), .driver_info = DEVTYPE_3M}, ' in CONFIG_TOUCHSCREEN_USB_3M section[/LIST][/LIST]
Say Y here if you have one of the following devices: - 3M PCT touch screens
- ActionStar dual touch panels
- Cando dual touch panels
- Chunghwa panels
- CVTouch panels
- Cypress TrueTouch panels
- Elo TouchSystems IntelliTouch Plus panels
- GeneralTouch 'Sensing Win7-TwoFinger' panels
- GoodTouch panels
- Hanvon dual touch panels
- Ilitek dual touch panels
- IrTouch Infrared USB panels
- LG Display panels (Dell ST2220Tc)
- Lumio CrystalTouch panels
- MosArt dual-touch panels
- PenMount dual touch panels
- Pixcir dual touch panels
- eGalax dual-touch panels, including the Joojoo and Wetab tablets
- Stantum multitouch panels
- Touch International Panels
- Unitec PanelsMeasy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Originally posted by mo123 View PostHi
Please try my 3 new MT5931 wifi & MT6622 bt test kernels.
If they don't work, I'll remove them to not confuse people.
If they work, I'll also move them to my thread to not interfere with d33's kernels.
No problem with mixing in here - great to have two of us, especially as I have so little time through the summer.
I thought that setting the GPIOs in bt_plat_smdk.c would get this working but no joy. Where did you add the right GPIOs for BT?Measy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Last edited by d33; 10 August 2014, 22:02.Measy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
BT finally works in my CS968 using D33 Kernel
D33/Mo123, finally BT is working with the #17 above!! I was able to pair it with my phone and even tried tramsferring two files...
Thanks D33 and Mo123...you guys rock
D33, I did not exactly follow the difference between the #17/#18 ? Should I try the #18 as well?Tronsmart Orion R68 Meta
CS968 -> HTC_T018 v4 20131216 with MTK
GM282 (aka CX 919 II aka J22) - dead
Yes please. Quite important to test 18 too.
Can someone post DMESG?Measy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Thank mo123 and d33 for your help.
Kernel17 works fine (wifi and bluetooth).
On 18 only wifi.
Here is dmesg of kernel18.
dmesg-debug18.txt
Kernel17 is 1080p. I have problems with my tv (flickering).
I can change resolution by wm command, but fonts and icons do not look fine this way.
Can you please make new kernel17, but 720p please?
Best Regards,
Benobi
There are currently 2186 users online. 0 members and 2186 guests.
