Kitkat Kernels for All (well most!)
Originally posted by m4f1050 View PostMeasy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Crap! 7am, gotta get ready for work... :-/
If you want to try one more before I get ready for work let's do it. I get back home around 6pm EST and can continue if you're up for it. I'm a bit tired... but happy we got wifi up and running! :-D
EDIT: Left stick with VNC, ADBWifi and SSHDroid running NOW THAT WE HAVE WIFI! WOOT! I can still debug once in a while from work.
You can try with 3.1 ROM now - edit note the CPU is overclocked now and working
1.6 / 600 / 720Measy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Originally posted by d33 View PostI'm out of thoughts really. Will revert to GPIO3_C7 for BT power but that is debug 6 really.
1.6 / 600 / 720
For NCR 3.1 we would probably have to wait when I get back because we don't know if the stick will have wifi for me to remote into it.
Originally posted by m4f1050 View PostYes, I saw that on No-Frills software, 1.6 is available, awesome! I have heat sinks on my sticks.
https://www.freak-tab.de/d33/kernel_..._debug8_oc.img uploadedMeasy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Just downloaded debug8.
I have mk809iii with 3188T cpu.
Just saw m4f1050 replied he now can set cpu to 1.6GHz.
Do you know he has the same CPU is me? Max i could set was 1.4Ghz always.
Cant upgrade this kernel now (im at work) but will do that once i home.
If WiFi works - will be avaible to make bluetooth ON too?
Regards,
Benobi
BT is not working yetMeasy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Donate to Finless
Donate to Finless
Originally posted by m4f1050 View PostIm at work, but should I try debug8, 9 or 10? I'm guessing 10?
EDIT: Also, could it be possible to just overclock CPU (gpu and ram I don't have heatsinks on them, if the o/c is not wild and they won't suffer from o/c then I assume it's ok?)
So far no-one has overheated at 1.6/600/720 so I wouldn't worry!Measy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
1366x768
Originally posted by nagper View Post
D33,
I just want to make sure you didn't misunderstand my situation and I am not wasting your time with my dmesg outputs.
Everyone else seems to be having issues with their Wifi/BT chipset except me.
My Wifi/BT always worked with any kernel (including yours) officially supprots AP6210.
I only would like to have 1366x768 resolution what is my TV-s native resolution.
Using my laptop with Win7, EDID info gets to Win7 and the preferred 1366x768 resolution is automatically activated.
Thank you
Nag per,
As explained a page or two back. Excuse me if I'm telling you things you know already
1. Desktop resolution is not the same as HDMI output resolution
2. Currently I can select 1920*1080 desktop or 1280*720
3. I specify acceptable HDMI resolutions in source code.
4. The HDMI driver requests CEA compliant HDMI modes from the device. If none are returned it assumes the device is a DVI device and accepts DMT but switches off audio
- 1366*768 is a DMT standard
- 1920 and 1280 are CEA
5. I can force DMT HDMI modes but I lose CEA modes
6. EDID information returned from a device is grouped into CEA and DMT
Given that far more people want CEA modes I'm not doing 5
Also the desktop will be scaled at that resolution and so will look poor
The best solution will be to make a dedicated kernel with a 1366*768 desktop and forced DMT HDMI option to match.Measy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
There are currently 2000 users online. 1 members and 1999 guests.
