Kitkat Kernels for All (well most!)
    Originally posted by m4f1050 View Post
    Here is a 720p of NCR MTK 1
    Lots of messages from the driver but none explicitly telling me where my config fails :-( Can you do a GPIO dump using the stock kernel?
    I've found this elsewhere which may be useful:
    <6>[15233.706777] =====MT5931 PIN DUMP=====
    <6>[15233.706783] GPIO_WIFI_EINT_PIN=[187]
    <6>[15233.706789] GPIO_WIFI_PMU_EN_PIN=[122]
    <6>[15233.706795] GPIO_WIFI_RST_PIN=[185]
    <6>[15233.706801] GPIO_WIFI_CLK_PIN not defined
    <6>[15233.706807] CUST_EINT_WIFI_NUM=[13]
    Donate to Finless
      Please test this one:
      4.2.4 MT5931/mt6622 (PC7/PD1)
      This uses pin configs suggested on another web site.
      [edit - re-uploaded at 10:28 CET to have CEA detection back on]
      I've also created (hopefully) a debug version that dumps the GPIO structure
      4.2.4 - debug
      Donate to Finless
        Here are all the latest builds:
        ESP8089
        MTK7601U
        RTL8188EU
        MT5931
        RTL8723AU
        Donate to Finless
          Here is my dmesg for the 4.24 kernel.
          my stick: mk908II
          I would like 1366x768 resolution support
            my stick: mk908II
            http://pastebin.com/ZfcsmmXA
            Nagper, you have a device with an AP6210 wifi chipset, correct? Or am I mistaken?
            Donate to Finless
              Yes you are correct.
                AP6210 debug
                Donate to Finless
                  Originally posted by d33 View Post
                  My kernel creates a desktop of 1920x1080 and then passes that to the HDMI controller. This then scales to the monitor resolution at a specific frame rate. Most people, but not all, want this size desktop but confuse HDMI resolution with desktop resolution.
                  The code I've used so far (up to 4.2.3) creates a set of CEA HDMI modes (TV standard) provided by of the device connected. It won't display CEA modes I've not coded for and it won't detect non-CEA modes even if I do code for them.
                  The latest code (4.2.4) introduces a patch to force DMT (PC Monitor) display resolutions to be detected (specifically 1366*768). So the desktop will still be 1920x1080 but the screen will scale to 1366x768 and use the appropriate refresh frequency. Standard CEA modes will not be detected, and hence, won't be displayed
                  My question to you is, since you are currently my only tester, what native resolutions does your connected monitor/tv have? Do they match the three the kernel presented (1366/1280/720)?
                  I think I want to combine CEA/DMT modes in one output.
                  I understand. And no, my TV only has the "regular" ones: 480, 576, 720 and 1080 (that I know of, no wide ones or special ones and will complain when any other is selected, even thorugh it's VGA port, it's a cheapo 40" sceptre dumb tv - as in not a smart tv like my LG or Vizio are)
                  To be specific, the HDMI resolutions I have (not the desktop resolution) are:
                  720x480p (60MHZz)
                  720x576p (50MHz)
                  1280x720 (50MHz and 60Mhz)
                  1920x1080p (24MHz, 50MHz and 60MHz)
                    4.2.4 - debug
                    I will test this, thank you for your great work!
                    EDIT: When I try to do a GPIO dump on NCR MTK 1 it is complaining "user-gpio-drv.ko" is missing - I can try NCR 3.1... but now I have the resolutions I listed.
                    EDIT: Does the debug kernel already give you the GPIO switches on a DMESG dump?
                    ncr_mtk_1_debug.txt
                      dmesg:
                      Thank you!!
                        Re: Kitkat Kernels for All (well most!)
                        [ATTACH]7272[/ATTACH]
                        The WiFi appears to work now but there is an error in the sdmmc code
                        Code:
                        <4>[   49.452816] rk29_sdmmc_command_complete..2875...CMD5(arg=0x0), hoststate=1, errorTimes=1, errorStep=0x1e ! [sdio]
                        <4>[   49.453306] rk29_sdmmc_command_complete..2875...CMD55(arg=0x0), hoststate=1, errorTimes=1, errorStep=0x1e ! [sdio]
                        <4>[   49.453786] rk29_sdmmc_command_complete..2875...CMD55(arg=0x0), hoststate=1, errorTimes=1, errorStep=0x1e ! [sdio]
                        <4>[   49.454265] rk29_sdmmc_command_complete..2875...CMD55(arg=0x0), hoststate=1, errorTimes=1, errorStep=0x1e ! [sdio]
                        <4>[   49.454741] rk29_sdmmc_command_complete..2875...CMD55(arg=0x0), hoststate=1, errorTimes=1, errorStep=0x1e ! [sdio]
                        <4>[   49.455216] rk29_sdmmc_command_complete..2875...CMD1(arg=0x0), hoststate=1, errorTimes=1, errorStep=0x1e ! [sdio]
                        GPIO driver not properly loaded will recompile later
                        Donate to Finless
                          TV Stick tests for MT5931 & AP6210 with GPIO_DUMP compiled in
                          Donate to Finless
                            AP6210
                            stick= mk908II
                            dmesg:
                            Thanks!!
                              Here is DMESG (switched to NCR 3.1 because NCR MTK 1 was not allowing me to install certain apps - giving me no space left error when I have over 5gb free in data)
                              NCR_3.1_debug4.25.txt
                                [ATTACH]7273[/ATTACH]
                                WiFi not loading in that one at all - what's different????
                                This one has BT too
                                Donate to Finless
